aviateur17
Just want to clarify that I'm not looking for the full 395 watt output. I'm wondering why the output doesn't show any peaking but is flat topped all the way from 10AM to 3PM at 250 watts per panel. I would hope that I see 290 watts max due to maxing out the IQ8+ inverter. I can't believe that 250 is the max for these panels. I'm hoping there's something I'm missing.
Hey all, hope you can guide me on how to figure out why I'm being limited on my panel output. I live in Minnesota so the sun angle is low and limited. I have two working ground mounted JA Solar panels rated for max 395 watts each (JA Solar 395w Solar Panel 108 Cell JA-JAM54-S31-395MR). On Full Sun days at Noon I'm only seeing each one put out 250 or 255 watts max for a total of 500 to 510 watts. Each panel has a Enphase IQ8+ inverter with no other Enphase gateway or communication gear. My understanding is that the Enphase IQ8+ should max out at 300 watts or 290 watts continuous. I'm shocked that I'm not seeing that on these 395 max watt rated panels. I'm using an Emporia Vue2 to monitor the power coming into the circuit. It's probably not the most accurate device but should be fairly accurate. I'm monitoring the power output through the day and graphing via Influx DB and I'll paste the graph below. Starting about 9:30AM I get 500Watts and then constant and same all through the day until about 3PM or 4PM and then the panels start to shade. What's odd is that there is no fluctuation in that output. The ambient temp is about 30 degrees F and the panels are warm to the touch but probably not warmer than 80 degrees F with direct sun. I've tried different angles and can't get them to put out much more than 255 watts a piece or 510 watts total. I don't exactly know how to test the panels directly. I've been trying to read about shorting the leads and measuring current and measuring open circuit voltage but that would be with no load and that wouldn't be accurate. You'd need some type of load. I wonder if the Enphase modules are limited unless you buy their Gateway for $4000 or whatever but I'm not too sure on that. I would guess they wouldn't be limited but I wouldn't rule that out. I did previously have a cheap Chinese inverter and was only getting 215 watts continuous when using that inverter. They are probably sitting at a 15 to 20 degree angle. I'll see if I can post pictures but I've tried changing the angle and see no difference. Any help on why I'm not seeing 290 watts/panel would be appreciated. I'll post the spec sheet for the panels and a graph of my output with full sun. The spikes in the graph during the day were me doing some testing of angles and such so don't mind them but you can see the flat top during the day which seems to mean that something is being limited.
Thanks for any suggestions!
