Zwy
Solar Wizard
All members, please try to limit responses to topics, not members.
I have 16 JA 530W half cell panels and pull full output if there isn't any of that high wispy cloud cover. I have even pulled more than full output in the right conditions such as March, clear sky, snow on ground, and panels tilted to 65 degrees.i have 16 JA solar panels that i bought new, and I have 20 sharp panels that i bought used at 5 years old, of which 12 are in one string and the other 8 are in a separate string. . both panels were rated at 200 watts. neither puts out its max power but the 12 Sharp's put out more than the 16 JA solar ones hands down, and they are five years older, i think JA solar is probably overrating their panels output in some fashion.. .so its more of if lightening strikes and the air is filled with fairy dust you might get most of what they are rated at.
thats just my experience with JA Solar. YMMV
The response reminds me of the guy in the Youtube comments of a video posted by a member here that claimed his Sol Ark was pulling 6000W off arrays and the EG4 was only pulling 400W. The actual Sol Ark screen showed about 500W per string.
I will say this about any system that is working sub par. Double and triple check your setup, check your connections, minimize voltage drop, run voltage as high as possible with a SCC. Don't overpanel the SCC, keep amps to a minimum. If you do this, then either the SCC is to blame or the panels.
If you going to bash a product, be prepared to back it up and expect to provide data and possibly videos of everything, same SCC's, VOC, wire, same tilt and distance side by side, the only difference would be the actual panels.
