As long as the loads are consuming, yes. But once a load powers off, there is a delay before the inverter senses the reduced load and adjusts accordingly.battery charging power from AC goes in the same direction as grid assist to AC Load out of the inverter. Nothing is leaving the inverters AC input like a grid tie capable hybrid would do
And during that several ms delay, the excess power being inverted but no longer consumed goes out through the transfer switches…
Yes, opening the transfer switches isolates AC input from AC output and avoids any possibility of spurious exports.couldn’t the transfer switches simply be opened stopping power from going to the grid, then how would there be current going to the grid with the path cut off..
I thought this inverter didn’t use CTs
An inverter-charger that only uses AC input to power an AC-battery charger and never shortsAC input to AC output would avoid any possibility of spurious discharge. I’ve been looking for an off-grid inverter-charger designed that way it no luck yet… (in fact just started a new thread asking about exactly that ).yes, with my grid tie zero export inverters I see slight backfeed everytime a large load shuts off. I just wasn’t thinking that would also happen with an offgrid inverter.. but I guess if it has a grid connection that is being used as grid assist then it could happen as you explain. Although if the grid connection was only used for AC charging would backfeed still be possible?
My brother has one of those and you may be correct. But they are so big, so noisy, so heavy, such inefficient, so old, and so expensive that if those are the only option, I’d prefer to get a modern hybrid, leave AC input disconnected, and spend a bit more on a separate AC charger…I’m fairly certain the old Aims offgrid inverters only had AC charging without grid assist. Or maybe they didn’t allow for any grid connection. I’d think there was offgrid inverters with AC charging before grid assist was a thing.
Agree with both points,Grid assist is a useful function and more I think about it due to this conversation, It’s probably difficult to find many offgrid inverters that wouldn’t also allow the AC from grid or generator to passthru to the load if it already had the AC battery charging capability.
What you would really like is an inverter that always connects AC input to AC charger and only uses transfer switches to connect AC input to AC output under user control. That and maintaining AC output synchronized to AC input as Victron does would be The Bomb (at least if it costs much less than a Victron).However I’m sure there’s some that just don’t have a transfer switch and only have AC charging path to the battery.
But just modifying a hybrid AIO to be a true off-grid inverter and using the dry contact to control a separate grid-tied AC charger seems like a reasonable and not-too-expensive alternative…
