It 8% difference right now, but yes. The 350$ Shipping is making the big difference cost of the Ruixu.Yup @moc , all in appears to be the most cost effective per pack for Canadian consumers.
If you buy just 1 they are 18% cheaper than the new Ruixu but if you buy a set of 4 they are about 7% less costly.
So the more you buy the closer Ruixu gets to price,.. they are alot bulkier than the Ruixu 3U units though.
Ruixu just jacked up the prices on the Canadian website 1 day after offering a "preorder" discount... so AOLithium is by far the most cost effective option in Canada right now. There is just so little info about them.It 8% difference right now, but yes. The 350$ Shipping is making the big difference cost of the Ruixu.
Also AOLithium say taxes is included in the price and ship from Canada. Ruixu say there is a Toronto warehouse, but no mention of taxes and on checkout there seem to be no mentions of taxes.
This to me is a problem... Unless there is no taxes on solar power battery... (I don't think so), if I but with my business, I need taxes to be displayed in my invoice to get it reimboursed... So they both lose point there for me, but they do make it very economical, even versus buying it from the USA it a better deal in Canada I think right now.
I didn't see the Ruixu was 1U smaller. I don't know if that really bother me. Having the display might be more interesting to have. I could put 11 battery in a single rack 44 rack (if it handled the weight). Would having 3 more unit per rack be worth it with the Ruixu ? I don't think so... BUT handling the 3U vs 4U might be easier, but if you are 2 to install these batteries, then I don't think it really matter.
The different power terminal bug me more about both these units. I really like the idea of having a safer terminal to work with these units, but not if they are impossible to get and make out own cables. Also I would like to have a way to put a plate over the connector to lock screw them in place.
Aolithium is interesting for being UL Listed (if it really is listed in canada), it remove one more governement hurdle and can be installed and used with ongrid system without issues, and maybe even get tax credit for it.
RUiXU support 32 unit in parallel versus 16 for the aolithium...
I'm unreally undecided... Thanksfully I don't need battery this instant hehe
I am strongly considering it... In Canada they are $1499 CAD right now.. which is about $1100 USD when converted.. and free shipping.Oh boy. Aolithium running a special. Under $1300 a piece for 51.2v 100ah. Two for $2579. I should add two more to the two I have.
Those are some smoking prices and I just installed my panels.
How have the 2 you have been working @dstar ?.. is the SOC indicators working properly?.. will said his were wonky but I never saw any actual bench testing.. just some feedback as one of many stacks attached to an EG4 18K
I have 20kWh Ruixu kit on order but will be weeks before they ship so being able to get 25kWh with AOLithium and save $1000 at the same time is tempting.
Those cell voltages are accurate actually but look at the SOC. I was not cycling these batteries at all and I kept checking on them, and they always said full charged. Then when I hooked up a inverter, it showed low voltage. I check the cell voltages and they are too low as you can see. But it always showed 100% SOC. That is why I did not charge them. But the standby on this bms is awfully high. They need to change that. And the bus bar system. Just not that well thought out over allIs this reported by the BMS and also observable when measuring cells directly?.. They are ridiculously low price for Black friday deal and people are jumping on it.
Yikes, 1 volt on some cells? The balancer must be garbage?Those cell voltages are accurate actually but look at the SOC. I was not cycling these batteries at all and I kept checking on them, and they always said full charged. Then when I hooked up an inverter, it showed low voltage. I check the cell voltages and they are too low as you can see. But it always showed 100% SOC. That is why I did not charge them. But the standby on this bms is awfully high. They need to change that. And the bus bar system. Just not that well thought out over all
Yes that's exactly what happened. Most of these server rack packs have a storage mode if they are unused. Once it discharges it enough, the lowest capacity cell will shoot down to one volt. It has nothing to do with the BMS balancing ability. It's the idle consumption of BMS and that's it. And the soc meter probably resets everytime it's fully charged, that's why mine shows 100% even though they are all deeply discharged.I actually have a thought on this. You say "I was not cycling these batteries". Did you have the units on but neither charging nor discharging?
It is possible the BMS does have a high enough standby parasitic draw and this draw for some reason is not counted by the onboard shunt (it may be below the set threshold of the BMS) or the power supply to the BMS is bypassing the shunt entirely. If the batteries are left for long enough and not charged it is possible the BMS itself will deplete the cells and not report the draw under the SOC. For a normal user this is not a reasonable use case as these units would get at least some charge every day in an off grid solar setup and that charge would dominate the parasitic draw of the BMS itself. It does however look like an oversight by the engineers and is a risk - if a pack is not to be used it should be turned off.
If the BMS has a parasitic draw of even 5W it would deplete any 5kW pack in under 45 days. How long would you say you had the pack sitting not charging? This is very useful insight.
And once I have a LiFePO4 cell below 2.3 ish volts, I don't try to recharge. Not smart to do.
