Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
So are you still using the inverter with the firmware you switched that allows L/120v N120v? Is the inverter still shutting down within 2 minutes? Why does it throw out F08? Are you saying it says F08 when you try to power different amounts of load on each leg before installing the transformer?
so many questions about your statements.. I guess that’s due to a language barrier. You acted like you switched the 16k single phase Deye to operate like it’s splitphase. But then never clearly stated if you kept the firmware the way you switched it to or if you switched it back. That’s why it’s hard for me to understand what’s going on with the AFCI/GFCI
