Download this resource AND the Update Image as well. The Voltage Chart and the Update are handy to have at hand
General LiFePO4 (LFP) Voltage to SOC charts/tables 12/24/48V
LFP Chemistry closely mimics FLA BUT there is a GOTCHA... You can NEVER Equalize LFP, Bulk/Absorb & Float ONLY.
The Charging information on the battery pack is TOO AGGRESSIVE and pushes cells to the edge,
this is not good ! In fact you are likely never reaching 100% due to High Volt Disconnects from when "any" cell within the pack reaches 3.650 Volts. SEE the Updated Image BELOW (Copy & save it)
TRY THIS If you can configure/program your equipment.
Bulk: 55.2V
Absorb: 55.2V for 45 minutes (3.45vpc)
(some call this boost) *I run a Bank of 5 packs, but never actually runs the full 45mins because of EndAmps
Equalize: OFF
Float 55.0V (3.437vpc)
MIn Volts: 42.4 (2.650vpc)
Max Volts: 57.2 (3.575vpc)
Rebulk Voltage: 51.2 (3.200vpc)
End Amps: 10.0A (*1) ( Using Smartshunt to control) (Allows for full Saturation at set Float Voltage)
(*1): End Amps is calculated (100AH X 0.05 = 5A | 280AH X 0.05 = 14A)
EndAmps/Tailcurrent when reached will trigger SCC / Charger to drop to FLOAT (Constant Voltage - Variable Current)
