Currently at 3.319 on the charge side and 3.315 on the farthest side. Each side is 32 cells so your saying to have only have positive on one end and negative only on the other?Positive and negative cables both connected at same end of looong grow of batteries?
Would rather see one at each end.
What is the voltage, +/- on cell terminals of first cell, and of last cell?
Thank you for the information, I needed a few more lugs but will have a 3rd 40amp running which will be connected in the middle. In the evening I do turn off two since they are all the smaller bank. I can already see the increased usage with just one running all night.3.319 and 3.315 sounds good enough. But ...
Yes, prefer positive at one end, negative at other (if only one wire for each.) If two wires each, both ends seems good.
If you are already driving both ends of 32 cells (or is that both ends of 64 cells, and they jump across from one group to the other?) then measure in the middle, compare to the end.
The point was to find how far some some cells lag the others. Hard to believe far end of a long runs is just 4 mV different. 40A? That would be 0.0001 ohm (if all current drawn from end; it is really tapped off 32 or 64 places.
So I think it is middle of string of cells that will have lowest voltage.
The middle are now at 3.317, outside is 3.322 to 3.331. The new charger is doing well, nothing is warm anywhere on the unit.Before you connect 3rd charger in the middle, what is voltage in the middle?
If you connect three chargers, at 0%, 50%, 100% (both ends and middle), what are the voltages across cell terminals (not bus bars) at each of those locations, also at 25% and 75% (the new middles, the sagging center of suspension bridges)?
I checked all across the bank, they are much closer now, with the 3rd charger going. I changed the wiring and have been monitoring them. I do check and move the chargers around as needed as well.3.331 - 3.317 = 0.014V delta
Did you measure 3.317 after connecting the new charger (3rd one?) to the middle?
Measure a point that does not have a charger. Measure the 25% and 75% points, and remeasure 0%, 50%, 100%.
Repeat this test when some point reached 3.65V.
If there is substantial voltage delta up the knee of the curve, I think it will be useful to let them sit charging (constant voltage) waiting for low ones to catch up further, tail off.
