I went out late last night and removed exchanged the ecobox, this was the reason for the midnite breakers. Once in a while I go and just check all the combiners and voltages. I found something odd in the ecobox, I have no idea on what was happening. Any ideas on this?
These are doubled enclosed, it appears to have gotten hot, all voltages were fine and the scc amps was unchanged.
Looks like rust to me. Condensation?
Applied voltage relative to environment might enhance/suppress corrosion.
Unlike your new Midnight/CBI breakers, these aren't two poles daisy-chained but are actually at positive & negative voltages, correct?
The surge protector and breaker "+" terminal are of course at same potential. Maybe screw is of different metal/plating?
Runs cooler, so doesn't dry as quickly? Although short copper run conducts heat. But there will be a distinct temperature gradient, maybe breaker self-heats above dew point while surge arrestor does not. Really a "degenerate" case you could have to go out of your way to create.
"doubled enclosed" - sealed or vented? SMA cautions against working on their sealed enclosures under some weather conditions. Don't want to introduce and trap moisture.
Negative screw for surge arrestor is offset. Just manufacturing tolerances, not loose?
It is so tempting to put two wires in one screw terminal, isn't it?
For some reason, not allowed by code. Except when the screw terminal is a splice like a split bolt.
I've found ferrules intended for two wires. Finding UL listed ferrules and crimper (listed together) without breaking the bank is another story.
I haven't seen any reason I can't strip a length of wire in the middle as well as both ends, so I've slipped one through a terminal (similar to your bus bar) and put one end in each of the other components. That accomplishes the multiple connections with only one wire under each screw. So long as terminal is sufficiently large to slip over insulation.
One screw for blue wire looks like it was never tightened at all.
