I'm considering the switch to EG4 from Victron.
Current setup: 24V with a 3000 MP1, 100/30, 100/50, 250/70 CC and BMV/raspberry pi for VRM. 3200 watts of solar on the roof and about 400 amps @ 24v.
Wants: 6000 watts, mini split (240v)
Future Potential Setup: Two 3000EHV-48s, 4000 watts of solar, 400 amps @ 48v.
The pros of the victron is hybrid functionality. I haven't used this feature in about a year, but it's always nice to have. Without experiencing the lack of this option, I'm not sure how I feel about losing it. If I'm plugged into say 20 amp power at a friend or family's house, this power is only utilized under certain parameters? If I'm plugged into 50 amp, will is completely bypass the inverter?
If I have two 3000EHVs in split, does the power going to them need to be split as well (I.E. out of phase) or can I send the same phase to each and then have the inverters split the phase? My onboard generator is 10kw single phase, so I'd rather not screw up my inverters by sending incorrect power to them.
Any other regrets I may have about switching?
