want to wire a few outlets in the walls before sheetrock. not sure if i need a box. want to make it easy ?have a delta flo 2000
Why?Much better to install the wire and a "new-work" box before installing the sheetrock.
Then a 2x4 stud is holding the box instead of only the drywall. Outlets must be in a box.Why?
That's brilliant.Put the front of the box protruding, put the wires coiled up inside it, make sure that it is a solid fix. Mark the location on the floor and note the height just before you install the drywall. Then when you install the drywall give it a tap with a flat peace of wood to leave a mark of the outline of the box on the back of the drywall. Cut it out and you will have a perfect fit every time.
Why would you do this?No. You can run the wire and leave it in the wall cavity with some slack and then cut in a remodel box later.
They make old work boxes that screw into studs also, but they're more expensive. Nailing a box to a stud is much cheaper.
I would never use an "old work" box on an outlet just because that can lead to undue stress on the drywall. Switches I have no issue with as those don't get pushed/pulled on. But given the option I'll always do the nail-on if the drywall is open because it is cheaper and stronger.
The OP is much better off learning to do it right the first time rather than learning workarounds because he is inexperienced.
I typically install a box and put a "mud ring" around it. Sheet rock installer has to cut hole to fit over mud ring.
If you're going to have something like a slab backplash over it, there are deeper rings.
I had installed outlets as well, but trouble is they have ears sticking out, so sheetrock guy cuts to fit around those as well, and cutout is too large, needs larger switch/outlet plate to cover it. The ears are intended to bear on sheetrock, keep outlet from flexing back when plugging in.
At doorways, make sure framing or standoffs allow door trim and switchplate to be installed without overlapping (I've got a couple where I used miter box to cut plate on one edge so it fit.)
I suppose you could mark floor or something where the coiled up wire is and do old-work install. I typically cut a hole in sheetrock after finding stud with acoustic sensor. Drill through sole plate into basement, stuff wire through. Screws through side of box into stud. You can get a 4' long drill bit to drill sole plate from a light switch height hole. Drill has hole through it to attach wire to, use it to fish wire up so you can reach.
More of a pain I think will be replacing wire for an existing box. How am I supposed to accomplish that? (e.g. replace knob & tube with Romex or BX.)
Wow using a remodel box to mount a ceiling fan.Remodel boxes are not the wrong way. That's being silly.
They get used all the time in New construction for various reasons and are a tried and true method of mounting fans.
Very handy to be able to do final config after customer and builder have settled on the positioning of things.
They are not a "hack".
Just fish new wire.
Long, flexible drill bits, cameras and fish tapes.
The very definition of a hack!!!!!
I've professionally installed sheet rock/ drywall for over 10 years. If the "ears"I had installed outlets as well, but trouble is they have ears sticking out, so sheetrock guy cuts to fit around those as well, and cutout is too large, needs larger switch/outlet plate to cover it. The ears are intended to bear on sheetrock, keep outlet from flexing back when plugging in.
