Bluedog225
Texas
- Nov 18, 2019
- 2,914
With the recent heat wave here in the south, my panel temps have been over 145°F!. Production has taken a hit for sure.What's your Enphase Temps look like on the IQ8s? Here's a link for how to get them if you haven't seen it.
Here's one of my IQ7+s (looks like it's averaging around 50°C):
wireandcableyourway.com. You want Type TC-ER Tray cable. #8/3 wire. It is crush-proof PVC coated, THWN wire. It is approved in the US for Exposed Run, Direct Sunlight, and Direct Burial, so you don't need a conduit at all with this. It just requires a water-tight gland going into your box or switch. The Hoymiles microinveters use this #10/3 for the AC run, up to 24A per circuit, 30A breaker. You don't need a professional installer, just an electrician to make the final interconnection. Very cool stuff!What an awesome discussion. With all the regulations it seems you go with either a professional installed microinverter grid tie system on your house's roof or you stick up some panels in a tree, buy some stuff from China and locate some long and heavy extension cords to run your appliances. OR BOTH. That is what I am doing. Two batteries arrive Tuesday and I will be ready to test. What I need from the NCsolar guy is a source for fifty or one hundred foot 240VAC 8awg external use extension cords. I have a couple 3.0KVA center tap transformers ready to go. If all goes well I will put up a car port with fifteen panels for decking using the trunks from all the trees I need to cut down. Thanks to everyone for the entertaining information and opinions. Just kidding about the tree trunks. I have 4x4s.
None that I know of. My meter for testing the HM zero-export function, and export/var control functions won't ship until 8/23. So I've got another couple of weeks to wait until I can test that function. If it works fast enough, then they should be able to pair with an off-grid inverter as I did with my Enphase IQB3T. The IQ8 is the only one I know of that can honestly work off-grid, but it requires you have a grid connection and the SC2 and a cell modem to use it.Hey Todd-Curious if we are any closer to off-grid micros? I’ve got a big pile of panels and will start ground mounting when it cools off. Would love to throw a dozen on the roof.
That sounds line a good plan. I am a big fan of hardwired Ethernet so if you already have a trench open that is a good backup strategy to throw in some Cat 5 cable. I have a shed 150 away and my mesh network does not always work at that distance for some devices.Then run the total array (3 branches of 10 panels each ~50Amps 240V) from the Enphase combiner box in a suitable buried wire to my home, to an AC disconnect switch mounted on the home exterior for emergency shut down if needed.
I decided to keep the combiner box near the array, due to concerns about power line communication over the long run, and a desire to avoid running three sets of wires from the array 200 feet to my home. Is there anything wrong with this approach?
I see that most folks install panels on the roof, and then wire up the combiner box on a wall at ground level. So most folks have a short run from the panels to the Enphase combiner box then a second short run to the main panel to supply the generated solar to the home.
Plan is to use wifi to communicate with the combiner box, using a mesh router extension placed in an outbuilding about 140 feet away from the array. If that doesn't work , I will also bury a cat 5 cable in the trench, and connect but I am hoping I won't need to use that approach.
No idea what happens where you are but that's how it works in Australia.Researching solar systems today I came across a company that is selling a system that used Enphase inverters- I don't think I am supposed to link to it so I won't but I asked them how they were going to warranty an Enphase system when you are supposed to take all of those online courses. Their response was "The warranty claims will go directly through us, and we will assist in getting you replacements if needed."
Thoughts?
Then you rely on the installer and presumably they may get some compensation for their labor from Enphase or have that built into their price.Their response was "The warranty claims will go directly through us, and we will assist in getting you replacements if needed."
Thoughts?
My meter arrived. I had to ask Hoymiles to upgrade the firmware in the DTU but as of this morning, it is communicating with the WattNode meter via RS485, and I was able to enter a new maximum export kW value and watch the inverter output change within seconds. Very slick!None that I know of. My meter for testing the HM zero-export function, and export/var control functions won't ship until 8/23. So I've got another couple of weeks to wait until I can test that function. If it works fast enough, then they should be able to pair with an off-grid inverter as I did with my Enphase IQB3T. The IQ8 is the only one I know of that can honestly work off-grid, but it requires you have a grid connection and the SC2 and a cell modem to use it.
No. I have not. No one has suggested it was a requirement. My install is about as simple as it gets from enphase's viewpoint it's 30 panels and 30 iq7a inverters. Ground mount.Have you submitted a system design for review? This was required at least when I went through the process.
For provisioning a PV only, no storage, no PV backup, you don't need that.No. I have not. No one has suggested it was a requirement. My install is about as simple as it gets from enphase's viewpoint it's 30 panels and 30 iq7a inverters. Ground mount.
Can’t believe I didn’t know about this thread before now.Next are the load and transient tests to see how quickly it updates when the load changes. I'll keep y'all posted. The inverter runs like a champ on a 48Vdc battery with a 0.2 Ohm series resistor and a 15A fast-blow DC fuse. I now have a functional 2.56kWh peak-shaving energy storage system! I'm currently operating at a maximum of 356Wac, but I can easily connect the HM-1500NT, and have a 1.438 kWac output. Doubling what I get from my Enphase IQ Battery 3T.
If I recall correctly. His ESS is Enphase. I do not recall that Hoymiles has an ESS. I think what @ncsolarelectric has demonstrated is the Hoymiles can AC couple and he can confirm whether he has been able to demonstrate export limiting with the Hoymiles without additional hardware and software....with your Hoymiles-based ESS system you were able to configure an export limit..
Without making this into a sales pitch, which is forbidden here.Can’t believe I didn’t know about this thread before now.
Adding a post primarily so I can find the easily through ‘Threads with your posts’ but I also have an observation and a question.
The observation is that in general, the rules regarding use of Microinverters and ESS get much more complicated / dangerous when used for backup / grid-forming than when merely used to offset load whole grid-tied.
That is my primary interest, especially as California moves towards changing the rules regarding solar to make self-use a near-requirement.
For that use-case, the freedom to move between zero-export and export-below-NEM-cap is an important feature and I’m impressed that with your Hoymiles-based ESS system you were able to configure an export limit.
Would you mind to recap the minimum necessary hardware along with cost to be able to program the export limit for a Hoymiles-based AC-coupled solar/battery generator?
And a final comment is that there is probably at least one if not two interesting new threads that could be spun off from this as you move out of experiment mode into ‘look what I’ve got working mode.’
