I'd agree with OzSolar, looks like a clone of the Air403 turbine. Assuming it is, and that they copied all of the original's features, those AIR403's came in 3 voltages, 12, 24 and 48v; with the intention to be connected to a battery of that voltage. They had a built in charge controller, so no need to connect/disconnect it from the battery or add a charge controller or dump load. But a few things to be aware of:
Can't recall if that was one, but a few of those models from that company needed to have a load, their CC would fry itself if the rotor was turning with no load.
The Air403 used a unique blade design to limit power in high winds, the blades fluttered and stopped making power. Cleaver idea but VERY noisy.
I'd be sure it is connected to the right voltage battery, and one that needs some charging if you want to see its prop spin. But as said, in its current location you're not likely to be able to get much out of it.
