First time DIY build in garage running fridge, lights, miscellaneous. Has worked for a few weeks with loads up to 500 watts or so. The inverter is a Jiguun 2000w pure sine powered by a 200a LifeP04. Solar charged. The other morning I decided to run a space heater. At med setting (950w) it ran for 10 min then powered down for a few seconds then started up again. I left it on and it repeated the cycle. Still left it on, then it shut down even sooner like 5 min. It would always restart. Voltage was always 12+. I have run higher wattage (1500) but only for a minute or so. I tried a constant 650w load which ran without a problem.
So is this a defective unit or actually just over rated? It might not bother me much except my lights are on a remote rf switch and my router is also plugged into this which have to be reset.
