Hi Jason, just ordered mine, but half your quantity. How long did shipping take? And may I ask what kind of BMS did you decide on? Thanks, JeromeLfp Lithium Ion Battery Lifepo4 280ah 3.2v Batteries Cells 280ah For Solar System - Buy 280ah Lifepo4 prismatic Lifepo4 Cell 280ah rechargeable Lifepo4 Cell Product on Alibaba.com
Lfp Lithium Ion Battery Lifepo4 280ah 3.2v Batteries Cells 280ah For Solar System - Buy 280ah Lifepo4 prismatic Lifepo4 Cell 280ah rechargeable Lifepo4 Cell Product on Alibaba.comwww.alibaba.com
FYI, 64 cells in a 48V setup. 51.2V Nominal at 280ah = 51.2x280x4=57 kWh
$5398 total, with trade assurance, shipping, everything. = $5398/57 kWh = $ 94.13 per kWh, DELIVERED.
Good to hear! Mine are on the way. JFedEx notifies me that my batteries from Basen will be here on Wed the 30th! they were sitting at the customs from the Dec13th ~ 26th.
But it doesn't appear much of the busbar will be covering the cells terminal. I would either get longer busbars, or use short battery cables. Then again it all depends on how many amps will be going through your modified busbars.I think modification will be a brief visit with the metal cutter and chop saw or angle grinder.
I am probably just going to zig-zag it and put a 1/0 cable on the end to join the two 24V packs, like the one flat on the left in the picture.But it doesn't appear much of the busbar will be covering the cells terminal. I would either get longer busbars, or use short battery cables. Then again it all depends on how many amps will be going through your modified busbars.
Glad you finally got your batts. Was getting tired of listening to you whine all the time.I am probably just going to zig-zag it and put a 1/0 cable on the end to join the two 24V packs, like the one flat on the left in the picture.
I think something that looks the shape of an ANL fuse would be perfect. This way it could have two attachment points on the same end.Glad you finally got your batts. Was getting tired of listening to you whine all the time.
The 1/0 is a good idea. Since you're good at drawing, I'd clamp cells up, take measurements, draw a bus bar, then send the .stl to CNC for however many you need. The cheesy shit they send with our batteries isn't good for anything. I'd use 1/8 or 3/16 Alunimen but that's because I overbuild everything. That's also why I never have problems and nothing ever runs hot. And the terminals are Al, no Galvanic corrosion with mismatched metals/finishes.
i'm not a battery expert but that's an awesome price. Lishen supplied the batteries for a very large multi MW project up here in MN so i know they're decent...i'm curious, tho, on qc vetting. what iso protocols or other vetting was there that made you comfortable to purchase.. and what is the warranty and how do you return a battery if there is an issue.Lfp Lithium Ion Battery Lifepo4 280ah 3.2v Batteries Cells 280ah For Solar System - Buy 280ah Lifepo4 prismatic Lifepo4 Cell 280ah rechargeable Lifepo4 Cell Product on Alibaba.com
