IF you have any "Reservations" about the QR Codes, best to download & install the QR Code Scanner on your phone !
Scan and decrypt the QR code on LiFePO4 cell/battery
play.google.com
Cells that have been in "STORAGE" for over 6 months after production "need" to be Top Charged to ensure the electrolytes are fully activated, Top Balancing is better if doing so. You WILL get randomness between cells if that isn't done. A LOT of folks suffered this and refuse to accept why... won't get further into it.
I just commissioned 3 of my new packs: EVE-280AH Dual Hole Cells (A-Grade Matched & Batched)
These cells were Top Charged & balanced then installed with the new JK Inverter models (discussed earlier in this thread)
The cells have stayed within 0.009 of each other in ALL Packs through from 3.450VPC down to 3.000 and back up again. 1 Cell deviated by 0.020 when reaching the top of BULK charge just before transitioning to float voltage (3.425Vpc) but was quickly corrected by the active balancer that starts at 3.420.
BIG TIP
Before putting packs ONLINE in your bank, be sure to Calibrate the BMS Voltage to what the reading is at the Pack Terminals.
Use a 2 Decimal (3 = best) Accurate Multimeter to read the voltage on the battery pack terminals and enter that value in the JKBMS Advanced Settings. HINT:
If you have a YR1035 battery Cell tester (or similar) that will give you 3 decimal accuracy (just ignore the resistance reading). The YR1035 can handle 100VDC but other brands may not, so check BEFORE using it for such purpose.
