Mendo Home Power
- Mar 10, 2021
- 148
6000EX-48HV Issues with batteries charging above 54v with sufficient PV input in USE mode. The 20kwh of LI-Ion batteries are tested and not malfunctioning.
This is what I sent to EG4 tech support and Sig Solar around a week ago;
I purchased an EG4 6K Off-Grid Split Phase Inverter | 6000EX-48HV for a client as a replacement off grid unit . I am having issues with the charge on the batteries getting above 54v. I am familiar with the charge parameters. The unit is set to use as I have existing Lithium -Ion (NMC) batteries that I am using. The Bulk is set to 57.8v in setting 17 and the float is set to 57 in setting 18.. Solar input averages around 4 to 5kw for 5 to 6 hrs a day at around 240v DC. The previous charging on the old inverter brought the batteries up to float level by around 1:00pm on a sunny or partially sunny day.
Thoughts?
Thoughts?
