John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Why?I'm still building a shelf with PVC pipes and wood about 4 inch above the floor.
Because I have s robot vacuum cleaner and don't want it to keep hitting my cellsWhy?
Ok and for top balancing I'm looking for the amps to go to 0 right?3.65 is fine but not necessary. Just keep an eye on it and make sure the voltage at the battery terminals does not exceed that. Don't rely on the meter that's on the power supply...
Yes. The cells are not completely ballanced till the current is zero.Ok and for top balancing I'm looking for the amps to go to 0 right?
Thank you, I been watching Will's videos for over a year now and watch him top balance these cells.Yes. The cells are not completely ballanced till the current is zero.
Top Balancing LiFePo4 Cells using a low cost benchtop power supply.
To get the paper, click on the orange at the top of this page. This is a tutorial with detailed steps on how I top-balance my LiFePO4 Cells using a low-cost benchtop power supply. To get the tutorial, click on the orange "Download" button...diysolarforum.com
This is where I'm at right nowYes. The cells are not completely ballanced till the current is zero.
what is the voltage at the battery terminals?This is where I'm at right now
3.265 DC vwhat is the voltage at the battery terminals?
I understood everything thank you and yes you're right I didn't pre-charge them. Yeah I'm off the next 3 days so nothing else to do. So I can wait for them. I have another 8 cells to do after this set.Did you do a pre-charge in series or did you go straight to top balance. With 7A of current I am guessing there was no pre-charge. This is fine but it might be a long time before they are balanced.
Also, with 7A of current I can almost guarantee the voltage at the cells is somewhat lower than 3.65V. This is unfortunate because that means some of your energy is being lost in the lines. However.... it is not a problem. Just be patient and once the current goes down the voltage drops will go down. When the current gets to zero, the voltage drops will also be zero.
Just don't raise the power supply voltage to try to speed things up.
Is that voltage good?what is the voltage at the battery terminals?
3.265 DC v is fine. Ideally you would not have the voltage drop between the supply and the cells, but it is not a problem if there is.Is that voltage good?
A lot of folks only top balance to 3.6V. I like to go to 3.65V because I like to run my system chargers at close to 3.6V and want to top balance to a higher voltage. This level of detail is more a personal preference than anything else3.65 is fine but not necessary.
Thank you again! This is my first time making my own batteries. Kinda scary not to lie but I believe I watch enough of Will's videos that I have it down. And with you guys help too. So now I'm just waiting for the current (amps) to get to 0 and than I can add my bms to make my battery.3.265 DC v is fine. Ideally you would not have the voltage drop between the supply and the cells, but it is not a problem if there is.
As long as the voltage at the supply is not above the target voltage, everything will eventually equalize to the power supply voltage.
As @upnorthandpersonal said, measure the voltage at the power supply with a reasonably good volt meter. The displays on the low cost power supplies are sometimes off by as much as .05V (Usually it is more like .02V)
Its fine.Is that voltage good?
Roughly how long you think I have?People are probably tired of me saying this, but it is worth repeating: Patience is the most important tool to have when you are top balancing.
And I'm not even though Will did lolIts fine.
Its going to take a long time to top balance.
Just in case nobody mentioned it.
Do not turn up the voltage on the psu.
