These braided ones that I make are rated for 150A. They're 25mm2 (25mm wide x 2mm thick) - maybe this helps as a reference.
Everyone keeps referencing 300Kgf and 661Lbf, but what I really want to know is how many Stones force we are talking.
My guess is simplicity (as in its just a piece of copper, its cheap, and they usually come with the cells)
Short, large AWG cable seems common for connecting a bunch of LA batteries, but with the high number of cells and very short distance between cells, large gauge wire seems like more trouble than flat bars, braided busbars, or the CALB style busbars (which I think are a balance between simplicity, cost, and tolerance)
This is a CALB style busbar:
The left and the right are the same thing (the right side is just deconstructed) the CALB bars are many thin layers with some curvature to allow some small amount of flexing/expansion.
Here are CALB style busbars next to some very high quality looking braided bars.
And here is an example (I think, its hard to tell) of using wire instead of busbars as you suggest:
I totally agree with everything you said except one point. A couple of my cells are diluted and there is isn't any space at the ends of the busbars. They reach but just barely. I noticed this when I parallel top balanced. When I get around to reassembling the pack, I hope to make it more square.
I am not at all concerned about increasing cycle life because my cells are going to be used for back up in the event of a power failure. I will cycle them probably monthly. My only concern is preventing stress on the terminals.
This battery stuff is complicated but I am trying to keep it as simple as possible and stay away from the weeds....in other words not trying to be absolutely perfect...lol.
Let me clarify, they are nominal 25mm^2 but because they are braided, this is the equivalent of having two layers in the braid, making the braid 25mm x 2mm.25mm x 2mm = 25mm^2 ?
I am not the most learn-ed fellow when it comes to the complexities of current and AC vs DC and ampacity, but i'm also not the least learn-ed. From what I recall, issues with thin strands are an AC thing, not a DC thing, and even with AC they are most pronounced at high voltage.I thought that stranded copper was a poorer conductor, but have also read somewhere that this is incorrect?
So here is the thing I visualize. Others may disagree with me but I have found disagreements are good because I learn something new.Yes I agree with this assertion. I still wonder though what the genus for solid bus bars is?
Your thoughts or knowledge please? 'Cause I think this guy is looking at cable bus vs. solid to eliminate issues with swelling and terminals.
There may be cheaper options, that's just the first I found.Not cheap at all.
I paid same price for 10" 4/0 cables with ring terminals crimped on and glued heatshrink.
The braid itself is fairly cheap: https://www.gacopper.com/Braid.html if you want to go @upnorthandpersonal's DIY route.
Diluted like this.not sure what you mean by ‘diluted’ but if damage to terminals from swelling (and stress from solid busbars) is your highest priority, going to the trouble of making 7 (or whatever S - 1 is) short wires with appropriately-sized lugs on either end is probably the safest route.
Well there you go. I had forgotten about going with diagonal configuration and I thank Dzl for that photo and your insight into this. I thank both of you and I will look at it when I redo the pack. I think it's a great idea.if damage to terminals from swelling (and stress from solid busbars) is your highest priority, going to the trouble of making 7 (or whatever S - 1 is) short wires with appropriately-sized lugs on either end is probably the safest route.
Then connect diagonally rather than straight which has the advantages of:
1/ even more flexibility / give in the face of cell swelling
2/ cells are all oriented front-to-back meaning swelling should ‘spoon’ just like lovers in bed (meaning less overall and more uniform pack swelling than when cells are oriented back-to-back and front-to-front).
@Hedges, I have a picture of that from one of mine. It's a cold weld (done with a hydraulic vise preferably).
It will add length but if using a large enough awg it shouldn't matter?I like that diagonal idea too .... that would take a lot of pressure off the terminal. I will add quite a bit of length to the bus connections, however.
@Hedges I don't follow what you are asking him to cut? The outer long edges? Is that likely to have a meaningful impact for our usage (honest question, the complexiities of this are over my head)?
The busbars are what, 20mm^2.I like that diagonal idea too .... that would take a lot of pressure off the terminal. I will add quite a bit of length to the bus connections, however.
