So PG&E is operating cheap to increase their profit. Their old and poorly maintained equipment fails in a wind storm and starts a fire. And now they get to bill their customers more to pay for the damages they caused, while shutting off power to those customers. Hmmm. Does anyone else see a problem with this?
My January 2022 bill from So Cal Edison came with new higher rates as well. My off peak went from 20 cents to 30 cents, and on peak went from 40 cents to 49 cents. Those are a huge increase. 50% and 22.5% over what they were last year. But by adding the cost there, it is actually making my solar panels worth more. Just think about it. Every kilowatt my panels make is now worth 50% more to not have to buy the power from them. So even if every bit of energy I make is off peak, my 8 megawatt hours I made in one year is now $2,400 worth of electricity. That just dropped the payoff of my solar back under 8 years.
And the DC panels I want to add, which will make the power I use during peak rat, is now going to be generating 49 cent power. It is a smaller system, only 2,500 watts or so. So let's say it will make 1/3 of the power (it should do better, even with battery charging losses) but that's still 2,700 kilowatt hours at 49 cents is over $1,300 USD. If I want this added gear to pay off in 5 years, that gives me a budget of over $6,000 to spend on DC charging my battery bank.
What is going to mess this up is when they start to impose non energy charges. I really do not see how they can justify charging people for just having solar panels. That just needs to go away. But if they charge the rate structure, I can see something like this... Drop the price per kilowatt hour in half, for all customers, but then charge half of an average electric bill for a non solar user in "Grid maintenance charges". What that does is non solar customers pay the same, and even someone making all of their own power still has to pay half even if they never use a single watt hour. I can see some form of that passing, but they will need to be very careful how they word it to make sure it does not throw red flags. I would not object to a moderate fixed charge for keeping the grid available. But it can't be totally put on just solar customers.
And then there is the big debate about wholesale vs retail rate for energy pushed back to the grid. As much as I like getting full retail credit, I can see where this is not fair to the grid operator. Let's be honest, they do not pay any other source at those rates for electricity going to the grid. Going to 25% credit seems a bit low, but not totally out of line either. I think this will push more people to install storage, and make companies work on better time of use management software to allow solar plus storage customers to truly self consume all of our energy we produce. Who cares if they won't pay us for exported energy, if we never export any? Ideally, I want to store all the excess, and then use it all night, and basically run off grid unless my production falls short.
I see it pretty much as you do. Overall, I see 4 different issues that meet to be addressed:
1/ is the 20-year grandfathering that’s been agreed-to for the first 1.4 million NEM1,0 and NEM2.0 customers going to be changed/reduced? That’s a lot of voters and that’s a lot of delay due to lawsuits, so hopefully they ultimately decide not to change the grandfathering terms for existing solar customers.
2/ Export credit: these are almost certainly going down for new installs. 25% of retail? Wholesale pricing? In the end, new systems are almost certainly going to need to be built with ESS large enough to capture a full day’s production for consumption overnight. Until battery prices get much cheaper, that alone is a pretty big hit to break-even.
The export credit is absolutely immaterial for systems that capture 100% of production, so it really only enters into the equation once you consider summertime credits for wintertime consumption.
The more export credit offered during peak-production summer months, the smaller-sized array you’ll be able to get away with to offset annual consumption.
At full retail rates, you can get away with an array sized to match annual consumption.
At wholesale rates, you’ll need to practically double array size to offset most of your electrical bill - a 2X array should generate close to a full-days consumption on clear wintertime days, so the very meager export credits you generate in summer months when your oversized array is generating 2-3 times daily consumption will be used to offset consumption in winter Jen the weather is bad and production is very low/nonexistent.
At 1/4 of retail (which is what the CPUC was proposing before that authorized a rate increase), array size needs to increase by 1.5 lx to 2x in order to offset most of the annual bill…
My point is that whatever they end up deciding as far as export credit, it’s just going to translate into how much larger of an array you need to build (the impact/cost of which is continuously being offset by the trend to ever-cheaper solar panels).
3/ Minimum monthly charges to support a fair share of grid maintenance costs (including, apparently, fire-liability-related costs): this is the stickiest wicket. I think all of us solar customers agree that as long as whatever rules are defined, they apply equally to all customers and not just solar customers, we can live with it. Be it based on service size or peak power level imported or exported annually, any fee structure that charges for the actual benefit of having the grid available for backup is much easier to swallow than the array-size ‘tax’ they have proposed levying on solar customers only. So hopefully we see something more sensible/palatable when the new successor tariff finally gets issued.
And hopefully it also allows solar customers who have designed their solar systems so that they import only and never export to be treated exactly like non-solar customers (no NEM agreement, no special ‘tax’of any kind).
As some consultant wrote in one of the articles I read, how can they propose that you be taxed more on carrots you grow in your garden than carrots you buy at the supermarket?
4/ And the last issue may be rather minor in the context of the changes to export credit: monthly trueup versus annual trueup
Going to monthly trueup treats solar customers just like any other customer, but it absolutely hits the benefit of NEM. Of the export credits are being reduced to near-wholesale levels anyway, it’s really not a big deal (since you’ll need to double your array size anyway), so it’s really only material if they leave export credits at a level that allows summer overproduction to offset wintertime consumption.
As long as we are talking about new agreements only, I’d be perfectly fine with some solar-specific ‘tax’ or monthly grid-benefits charge that is only levied on those solar customers who choose an annual trueup plan (meaning those new solar customers who have invested in a sufficiently-large system to generate most of the power they need even in winter can be billed and tried-up monthly like any other non-solar customer without incurring any special tax or fees).
