tim0shel
- Jan 27, 2020
- 464
From my understanding it does not matter. I have read this somewhere and does not matter due to the nature of it being bidirectional. When BMS stops suppling power it cuts off power between the two terminal.Looks like the terminal on the right in this chargery pic…
My “guess” would have been that it does not matter but following the official pic should be safe(st).
Answer one comment you had above The fix for terminals (Don't know what version) length not the width apart. Before the nut would be almost mm away from the metal plate of the DCC. They are now extended a good bit.
Not sure if Jason is interested in this as much anymore or he has became supper busy. The communication was pretty great with him for long while but lately nothing. This AM I have emailed him again in regards to my DCC issue. I think my issue is it being one of the very first few told it would work in separate port and not necessary designed with the changes, such as later on you had to specify if it's use was in common or separate port, Was mentioned this is due to cable supplied with them but seems like it is something internally with the DCC because of a comment above from Jason. He mentions it should have a label on it etc. Also little bit later on the ability to run it on the positive side but only with the ISO board. So I think this also compiles to the issues if with earlier version. My DCC also has some issue going on due to the fan running non-stop. The spec sheet clearly states when it comes on and I was no where close to that temperature and no load because it will not connect, stays disconnected. Only one red LED on but the status LED only flashes a millisecond when flipping the switch on back of the DCC.
My newer ordered this year (Specified separate port) DCC-100 for the charge side works just fine. I need my load one working and my goal to have this built, tested with months to spare now comes to an end as I need it in NOV. But the response from Jason has not been that great.
