brandnewb
Going for serious. starting as newb
But not even 2 watts is a let down. surely we should ask isaac newton to look at our math should we? ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I dont have a wind speed meter but believe me it was fast. today was a good day in terms of wind. coming days will be slow ;(
THe blades spun so fast that you they turned to a blur when looking at them with noise and all.
But not even 2 watts is a let down. surely we should ask isaac newton to look at our math should we?![]()
lol, and you tell me after the fact or you did before and I only realize it now![]()
Yes, something like this is what I inspire. especially if he made it through the Texas blackout of 2020 as he is from Texas I think I gathered from that video
Yes, something like this is what I inspire. especially if he made it through last black out.
for real, So I was thinking about some kind of gear mechanism in where when there is no wind it is in 1st and when the wind starts getting stronger and stronger it will shift gears as to avoid the blades going to fast while increasing the power generation. I can imagine though that in that case sooner or later the blades will snap as they are cheap chine mass produced sub optimal produceNoise could kill your idea, especially if your neighbors are close by.
Lawn darts!! the best way to describe the risks I have seen as of yet.However, it's still a game of lawn darts with anything in the area.
I am such a d@#k headYou don't measure resistance when there is power on the wire, ever.
agreed.Your definition of "blur" is not exactly an accurate measurement. The wind speed and the RPM the motor turns is everything here.
Yes sir, understood. I am going all in now. Please advice what tools I need and i will make it so.Let me state again, to properly measure how much wattage it can produce requires proper test equipment.
I am such a d@#k headI am disappointed with my self for not beginning to learn about these topics much earlier. I am doing now though so I can pass on that knowledge to my offspring.
Do i need and should get one at the earliest?I don't happen to have a micro-ohmmeter
I'll try and put nuance to that.I personally don't inspire to lay in bed and listen to the out of phase rumbling sound as all those wind generators vibrate the roof. Or the massive raspberry sound as they overspeed in high wind.
Otherpower is the place for all things wind. @brandnewb m you might consider joining over there.Here is some cool reading. https://otherpower.com/otherpower_wind_tips.html
Also I am ready to cut up some wires of some regular single phase house hold appliances like toaster and what not.
But let me see if I can get that car light today @Porch is referring to.
But why 12v? why not bigger? perhaps they are not produced?
No joy regarding a 12 v car light and 3 wire fitting. Nobody local has it and/or is not open now so it will be days before I can finally proceed
shall I just sacrifce any and old single phase house hold appliance? A tv, Heardrier like you suggested. My laptop even perhaps?![]()
It just needs a way to regulate the generator itself. Exactly how a car alternator does it. Or adjusting the pitch of the blades. It's just added parts and cost and these little units are designed to be cheap.for real, So I was thinking about some kind of gear mechanism in where when there is no wind it is in 1st and when the wind starts getting stronger and stronger it will shift gears as to avoid the blades going to fast while increasing the power generation. I can imagine though that in that case sooner or later the blades will snap as they are cheap chine mass produced sub optimal produce
Except the heat, eh?No harm will come to it because the baldes can't spin fast enough so the blades will be stalled all the time.
