cs1234
Solar Wizard
- May 9, 2022
- 3,537
I post here first so others can be the guinea pigs. Just because I sound stupid, doesn't mean I am stupid.Get in on the ground floor
Right but then you’ll have to pay more once Will makes this company’s dayI post here first so others can be the guinea pigs. Just because I sound stupid, doesn't mean I am stupid.
I didn't summon him, I figured he would be too busy to notice with all the parallel testing of the 6000xp he should be doing.Right but then you’ll have to pay more once Will makes this company’s day
Not if they used Red LocTite 271 on the threads.If those are really screws holding the top on, you can even open it up and see how poorly it's built!
Nice price compared to the Amazon price on those.I use a couple of these :
ECO-WORTHY 48V 100Ah LiFePO4 Lithium Battery (2 Pack 50ah) Club Car Golf Cart | eBay
It weighs only 58.42lbs, only 1/3 of the weight of lead-acid Battery and only 2/3 the size of it. LiFePO4 Battery. 【Long life cycle】. Solar Panel Kit. Solar Battery System. More information. 【Travel Longer】.www.ebay.com
They are in parallel with a DIY 100Ah and one of the original EG4 (GYLL) batteries.
Yup, the deal seems to have ended. It's still one of the cheapest (if not the cheapest) 48v 50ah batteries on Amazon.. even without the extra $150 coupon.BTW, I don't see the deal anymore, maybe they saw this post, got scared someone may actually do it and post results.
It looks better inside than I thought it would.Since they didn't post the actual specs online but did put one in the box, I figured I would share it as well. Enjoy the pictures.
Nothing more than the blue wrap that every lithium cell seems to have.Any protection between cells? I don't see anything visible in the pictures. Also, much thanks for peeling the lid back and documenting with visuals.
Open it up and disconnect the BMS from the cells, that should reset it.Nothing more than the blue wrap that every lithium cell seems to have.
I'm more disappointed that they have a clear set of specifications on delivery but not posted like every other battery. The bms definitely isn't rated solo for the amperage required by a 3hp dc motor pulling a cart up hill.. glad I picked up a second unit. Maybe 100A will be fine.
Question, this unit doesn't have an on/off like other metal cased 51.2v units, so what happens when I go over 200A/10s or 50A continuous? I know the bms will shut off, when/what will get it back up and running?
Without any cell protection and the above wire potential for insulation abrasion, I'm unsure this battery would be suitable for any mobile applications.Hmmm... odd that the wires are unprotected as they enter the channels, but then they're shrouded in something fuzzy while in the nice smooth channel?
You are welcome for the info, knowledge is always good. I cannot see the BMS due to the recessed handle insert coming right into the face of the unit, thus the unit has a protective film on it. I'd have to pull it out to see it and I don't really care to do that just yet. If it fails then I will see if it's easy to pull. The cells are very well held with the cross bars so even though they don't have separators, I don't see the cells jostling around or getting damaged, I'ma run it on the cart in parallel, I'll use a DC up converter to push a 20v portable battery on my Bluetooth speaker up to 60v output just to reset the BMS in case I pop the damn thing at a start up, hill or WOT. Also, not on the picture, the tops of the cells have a piece of thin plastic plate that covers them up, not that it should really matter as the cross bars keep the cells secured, I just didn't take a pic of itConnecting it to a proper voltage charger should also reset it.
The build quality looks pretty decent. I like the balance leads are easily removed, this will make BMS replacements / upgrades easy. I dislike there doesn't appear to be any separators between the cells.
Can you see the front of the BMS to determine a brand?
Thank you @TheAngryGerman for taking a gamble for the community and for taking the time to open it up and post photos.
I see a QR code peeking up on the BMS between the blue and black wires. Any chance you can scan it and post the results?Since they didn't post the actual specs online but did put one in the box, I figured I would share it as well. Enjoy the pictures.
