Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,682
50 kWh/day in summer is not a big deal to implement. 8kW to 10kW of panels, can be had around $2500 for old stuff, $4000 for relatively nice, $5000 and up new. Some inverters in the $1500 range, similar for 5kWh batteries. If you scrounge mounting hardware, might spend as $6k to $10k for a system with 10kWh storage, buffering loads like A/C all day long and modest load at night. About $80/month amortized over a decade.
5 kWh of batteries is a good buffer for daytime usage, like big PV array and inefficient A/C. So long as you don't have to run A/C after sundown.
PV strings aimed and morning and afternoon sun will provide more flat power curve.
Something like this at the house:
And these (assuming they work even though they say "for repair") at the array:
Or up to four of these, if you're not a gambling man:
Would give you a powerful system similar to mine.
I run AC all day no problem, may not make it through the night with multiple old refrigerators, yard lights, tube amp.
These could cost you $7600 plus shipping and maybe tax.
12kW from batteries + 24kW from PV.
Have to pay attention to what batteries you want to use. Lead-acid is easy, but for lithium it is preferred they have compatible BMS.
Battery Inverter Solar Cabinet: (QTY 2) SMA Sunny Island SI-6048 w/ Warranty | eBay
These cabinets were designed and built by DC Solar. If you use the cabinet as-is there are only 2 connections required to have a functioning system (battery connection and solar panel connection). This setup will generate power even when there is no connection to the power grid.
www.ebay.com
Lot of 4 - SMA Technologies Sunny Boy (3) SB 5000-US Inverter, and (1) SB 7000 | eBay
Find many great new & used options and get the best deals for Lot of 4 - SMA Technologies Sunny Boy (3) SB 5000-US Inverter, and (1) SB 7000 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
SMA SunnyBoy SB6000 US 6kW Solar Power Inverter - w/ Mounts + AC/DC Disconnects | eBay
Find many great new & used options and get the best deals for SMA SunnyBoy SB6000 US 6kW Solar Power Inverter - w/ Mounts + AC/DC Disconnects at the best online prices at eBay! Free shipping for many products!
www.ebay.com
