Going from memory here, but this would be my initial test procedure:
- Visual inspection to look for damage, test fuses, document as-found voltages at various parts in the system.
- Check continuity across pre-charge switch and make sure it matches its expected mode.
- Shut down all equipment to the extent possible.
- Check 400A fuse; remove to test upstream.
- Jumper over fuses with small test leads and check pre-charge sequence and voltages throughout system; keep inverter and mppt shut off.
- Assuming all is normal, re-install fuses and repeat previous test.
- Perform visual inspection on PV connections to trailer, check voltages.
- Perform startup.
What test equipment do you have? Generally the more information you can record the better.
