42OhmsPA
What's in a title?
Thank you. I'm also debating an electric or heat pump water heater...Keep in mind these are regular electric heating elements. I measured them using my new toy, a Klein C390 clamp/voltmeter. I took off the door from our house electrical panel and carefully took some AC current readings.
Some other readings-
Dryer - 25A (6kw)
Water heater - 15A (3.7kw)
Oven - 11A (2.5kw)
Electric heat - 50A (?!?!) (12kw)
So, yeah we try not to run the heat too much. If you don't like a cold house, don't stay with us, we usually keep it around 65F in the winter. That's why I try to take advantage of sunny days and use the space heater for free.
I've been impressed with my mini split to supplement the coal stove.
I'm betting you have some great insulation and air tightness.If it's 30F or so ambient I can heat the 1300 sqft house with two portable oil filled heaters, 1500W each, 72F. Once it drops to 20F need to throw an extra blanket on.
