FilterGuy
Solar Engineering Consultant - EG4 and Consumers
Sorry. Ioc was a typo. It should have said Isc and I corrected it above.I searched for Ioc limit on this forum but this posting and another looking for specs on PV panels are the only ones that mention it.
I am not aware of the term Ioc limit, so would like to know more!
Note: Ioc would always be zero. (You can't have current in an open circuit).
We need to be specific.So if an mppt input is rated for 3000 watt but you oversize it with 5000 watt but not get near the max current limit, it will not be a problem.
But being able to pull more current than the mppt has specified is a problem ?
There are two different kinds of specs
1) Specs that are limits of what the system can be exposed to
2) Specs that describe the capabilities of the system.
Limit Specifications:
For the 18K pv there are a few limits to what the MPPTs can be exposed to:
- Isc (31/19/19A)
- Voc (600/600/600V)
- Total array PV power for all three MPPTs. (21KW).
Capability Specifications:
For the 18Kpv there are several capability specifications:
- Usable IMP current: (25/15/15A)
The Imp current spec tells you how much current the MPPT will use but does not specify a limit on the solar array. Even if the solar array is capable of producing a higher Imp, the MPPT will not use it. - Usable PV power of all three MPPTs: (18kw)
This spec tells you the total power the 3 MPPTs can generate. Even though the the PV arrays might be able to generate more power, the system will not use it. If the total generated power reaches this limit, the MPPTs will start limiting the amount of power they will harvest from the array. - Full power MPPT Operating Range: (230V - 500V).
This tells you that the MPPT will do power point tracking in this range. However, the system can still work below and above that range (up to the 600V Voc limit).
Unfortunately, it can sometimes be an art to understand what is a limit spec and what is a capability spec. EG4 has been getting better at clarifying this but *all* solar equipment manufacturing companies need to improve.
