FilterGuy
Solar Engineering Consultant - EG4 and Consumers
Where is that statement from?- Damages incurred from voltage or current spikes due to open-loop lithium battery communications
What about DIY LFP batteries (that lots of people have here) that don't have that convenient ethernet cable connection? Are you really going to void people's warranties because they do not have an EG4 battery?you are having 2 FET bridges (BMS and Inverter) fight each other because amperage/volt ramp-down really only works well with lead acid. the inverter is pretty responsive and high-powered on the software but BMS quality is always a question to go along with this. have seen this break cheaper inverters and BMS's, also skipping closed loop ends up in firmware regression sometimes as we cannot, and will not guarantee best operation without closed loop (e.g our train wreck 8kw review)
It's an ethernet cable, the setup is very simple. please do it lol
They could integrate REC BMS with the inverter, then you can have DIY batteries. There are a lot of new BMSs out there that support communication, even some of the new JBD's have RS485. Also they added support for a ton of different battery companies, SOK included, so you are not in any way trapped into using EG4 batteries specifically.What about DIY LFP batteries (that lots of people have here) that don't have that convenient ethernet cable connection? Are you really going to void people's warranties because they do not have an EG4 battery?
I have never heard of anyone's inverter blowing up because they didn't have BMS comms set up. Plenty of oddities with BMS comms set up though (not necessarily with EG4 batteries, just speaking in general).
I don't know if he will do it, but I asked @Will Prowse to do a battery-build video with a BMS that does closed-loop coms with an inverter. I think the people building batteries from cells would appreciate it.What about DIY LFP batteries (that lots of people have here) that don't have that convenient ethernet cable connection? Are you really going to void people's warranties because they do not have an EG4 battery?
You can use it all day, you just forfeit your warranty.You have to click on the "Warranty Information" tab.EG4 18kPV Hybrid Inverter | All-In-One Solar Inverter | 18000W PV Input | 12000W Output | 48V 120/240V Split Phase | EG4 18KPV-12LV
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LLsignaturesolar.com
If I use JK BMS's that means I basically can't use the 18kPV?
Could these 2 separate battery banks be charged separately at different voltages or at lead different float or absorption voltagesI sat in on a training call for these units this last week, and some of the most impressive features of the inverter benefit most from communications - for example, from what I understand, you can have two inverters in parallel with completely separate battery banks connected to each inverter that properly share the system loads to prevent from over-discharging one battery bank before the other.
The multiple banks feature excludes lead acid for nowCould these 2 separate battery banks be charged separately at different voltages or at lead different float or absorption voltages
I though he stated that he had comms connected with only two. I guess I just assumed it was his Jumbo battery pack with comm hooked up on only two of the batteries.For reference the manual states: "EG4® strongly recommends using closed-loop communications between your battery and inverter."
I could not find anywhere that states what BMS's are compatible or even batteries. Is that listed somewhere or must you only use the EG4 batteries with the 18kPV to have a warranty at this time? I did notice Will in his video specifically connected it only to an EG4 server rack batteries.
So to ask my question again, is the warranty void if ANY battery without Comms is connected? For say a Daly BMS with no communications? Or is it only void if the damage is confirmed caused by the BMS with no Comms? Because if the screen burns out, and I send the unit back, but i never had a BMS with communication hooked up to it. I'd be pretty upset if it wasn't covered.we are open to comms with any bms our customers need, frankly they are an inbred family and odds are that they are already compatible, just have to try it out and fw update the bms possibly, this is a DIY bms mfr problem which we can supprt but they have to support and own the help
A reoccurring theme!I have to say that I find this tidbit about not supporting / voiding the warranty when used with lifepo4 batteries without comms very disturbing. Especially considering my love of 12v batteries in series that don't have comms...
To avoid issues, like I had with Fortress power, I humbly suggest having a disclaimer stated very boldly that this inverter requires battery comms in order to have warranty coverage.
It shouldn't even have voltage modes if it doesn't warranty them, or it needs to be programmed to tell you, "Are you sure? This voids your warranty."A reoccurring theme!
I had no idea why Fortress power said that there version would not be warrantied unless it is hooked up to Fortress Powers Batteries in closed loop. I wonder if the Inverter has issues with Voltage modes?
Honestly, it's a good question, have you read the warranty? Do you use batteries without comms?Do I have to worry about his with my Sol-Ark 15K?
None of my equipment is installed yet, but I am building batteries with seplos Bms, so I should have comms.Honestly, it's a good question, have you read the warranty? Do you use batteries without comms?
Warranties are here and only thing that remotely comes close which doesn't sound like it:Honestly, it's a good question, have you read the warranty? Do you use batteries without comms?
Battery Agnostic
Sol-Ark inverters also do not have expensive battery restrictions like other solar inverters do, and can be used with a wide variety of 48V battery chemistries, from lead to lithium.
What is the purpose of seperate battery banks? I don't understand why someone would need that?Sol-Ark:
Now that said, Sol-ark lacks the functionality of having multiple, separate battery banks. There is a fine line where you trade compatibility with everything for added functionality.
