Hello,I am sure you will like it. The 18 amp version came out soon after I received the 12 amp version. It comes with a temp. sensor too which I taped to the top of the power supply.
As I recall setting to 3.4 volts dropped the current quite a bit. You will find this out. What you could do is set it to 3.65 volts while you are attending it. And shut of power going into the cells when you can't be around to watch. As long as the power supply is left on it will keep tracking the total amp hours and watt hours going into the cells. You will see all of this once you put it together. I found the instructions to be very helpful.
I did test it on my Valence batteries before I started my top balance. So if you have a battery you can test it on for peace of mind that would be good.
One other thing...get the clock battery. Especially if you got the wifi board. You want to put the battery in because the wifi board covers it up and it can be tricky to remove for the battery install as I found out.
Ho yes, thanks, the battery is a CR1220, though it was included. Yes I would do something like that and stop charging for a night or so if I can't be awake when interesting things happened .
Seems the RD6018 got a power limiter function that is not present in other model, I dunno when it will be useful to me, but still..it's here.
