Hello all,
I will receive my cells (hopefully) in 2 weeks
1. I top balance them individually at 3.65v under 14A, let them rest for 2 days, check
2. I top balance them all 16 cells in parallel at 3.65v under 14A, let them rest for 2 days, check
In the second case cells will certainly stay a longer time at 3.65v cause, I suppose, most of us do not have tremendous chargers.
(I followed the discussion but I may have misunderstood some english expressions)
So, in the end...what is the the best way we have (with small charger, my Riden is on the way) to deal with this top balancing (which certainly already have been done at seller office, at least celle per cell)...…?
Thanks and sorry if this question as already been asked a zillion times, I kind did not find the clear answer (taking into account I do not understand English perfectly).
So which Riden did you order? Did you order the complete kit with the power supply? The 12 or 18 amp one? If you ordered the one that comes with the power supply you can safely run it at it's full output. The 18 amp version only draws 65 watts and the 12 amp version only draws 44 watts from the power supply running it's full output at 3.65 volts.
The Riden has a battery charging feature, and over voltage and over current protection, so you can skip the step method if you are comfortable doing so. I started to do the step method myself but the current kept dropping too much and it gets to be very time consuming. I was confident enough to sleep while it was charging. I was happy I was awake when it reached the end of charge so I could make sure it would shut down. It did. But I had the OVP set I think at 3.7 volts just in case.
The Riden comes with fork terminals. I used those for connecting to the Riden and made 12awg cables and put ring terminals on the other end for connecting to the cells. You want good connections. Following is what I did using the Riden:
1- Verify cells are at similar voltage, prior to wiring them in parallel.
2- Wire the cells in parallel
3- Set the Riden to 3.65V and it's full output current. Note: I used the full 12 amps of my Riden and it didn't burn out. It's not going to because the 3.65 voltage is so low.
4- Turn on power supply and charge cells to 3.65V
5- When current has dropped to 90ma's the Riden will cut power to the cells and stop charging.
6- Done, pack is balanced.
You can connect the Riden to the cells, turn it on and set the voltage. It has a button to start power going to the load. It has a separate button on the front to turn it on and off. And it has a switch on the back to power on/off the power supply.
I do believe the step method is a very good idea if using a traditional power supply mainly to avoid overcharging the cells. Once they reach 3.4 volts the voltage will start to rise quickly.
Following are some notes I took while I was parallel top balancing my 8 cells with the Riden:
Started charging on 10-30-2020 at 7:45PM. During this time I tried the step method and decided to skip it. Due to the low voltage there wasn't enough current going into the cells and I set the Riden to 3.65 volts to get the full 12 amps.
11-4-2020 9:14 PM. Charger switched to CV at 3.60 volts but still charging at 11.98 amps. The voltage at the cell terminals was 3.391 volts. Voltage at cell terminals when charger displayed 3.65 volts was 3.443 but it did go into absorb mode. Current on the display is 1300ah's and wattage is 4595wh's.
11-5-2020 1:10AM. The voltage on the Riden display was fluctuating between 3.64 volts and 3.65 volts. The voltage on the cells is 3.65 volts and occasionally I got a reading of 3.651 volts. The current on the display at the tail end was fluctuating between 210ma's and 120ma's and acted that way for awhile. Finally when I noticed the current drop to 90ma's the charger cut off. The current going into the cells as measured by the Riden was 1305.59 amps and the wattage was 4613.86.
The only bad thing about the Riden I have found is it's cut off current. The manual states the Riden will cut off when the current has reached 100 ma's. It has been suggested to Riden to make that adjustable.
Also the Riden switches to CV about .5 volts lower than what the charging voltage is set to. This doesn't effect anything. Other than that I love it!
