My gut says 48 volt; 100 ah; at $1,200 by midsummer. Without the fancy stuff.
I contacted Amy the other day, 16S 280Ah pack would cost $2381 shipped to my door. I could add another 48V 280Ah to my bank with another K9 from Batrium for under $200. Granted, the initial investment with the Watchmon CORE with 1 K9, no fuse holders or extended comm cable would be around $600 plus some shipping. For 2 48V assembled packs the cost would be $400 per pack for BMS. That's $2800 per 280Ah battery with some miscellaneous for 2 battery packs, it get cheaper adding more packs and K9's.
But what is the quality of the BMS in that 48V 100Ah $1200 battery? Do you compare the BMS in it with the Batrium?
We all can buy what those assembled batteries are using, usually a BMS in the under $200 range, 120Ah cells for $50 each from Amy. That's $900 to $1000 per assembled pack. What I'm seeing is the smaller Ah sizes are getting competitive to DIY to an extent ( although a $900 pack is 33% cheaper than the $1200 pack you think is coming). It is when you start getting to much larger systems that you see the discount DIY has over pre assembled.
I can add parallel cells to my existing DIY packs with those K9's but at $200 I think one is better off with individual cell monitoring. Let's say I add 2 more packs for a total of 4 packs of 280Ah, total 1120 Ah. $2381 x 4= $9524, Watchmon CORE with 4 K9's would be about $1200 with some shipping. With $150 shipping that puts the total pack at $10,874, let's just go with $11,000 as you have some supplies.
To equal that with 100Ah packs takes 11.2 of the pre assembled batteries. $13,440
DIY is still a 22% discount. If you parallel cells and run 2 packs, you save about $380 additional, that comes to just over a 25% discount.
Many of the pre assembled batteries are welded terminal, if you have a bad cell, you have your work cut out for you, if you can even replace it. With the DIY, you change out the bad cell and move on. Which pack will most likely live the longest and end up the cheapest per watt hour over 10 years for example?
