Bluedog225
Texas
Lottery for the old batteries!!!*
*Must have at lease 2200 posts to enter.”
Noooo it needs to be 900 post to enterLottery for the old batteries!!!*
Nice! One of my raw cells systems is still running:I think if you want to just buy one, or if you need ul, then probably the way to go. But I'll stick with my DIY. Under $3k each, 304ah, only 16" X 24", and around 210 pounds. I really wonder why their battery is so big and heavy. Pretty sure if I can squeeze the cells in this cabinet, they could too.
Don't they have to be three feet apart? Or would these be tested together in "clusters" of two and three to be permitted that way?Weight is the problem. They should make it in two cabinets you stack together. Ul9540 allows you to put 2 in the basement, 2 in the garage, and 2 outside. 6x14, or 84kWh.
3 feet apart. Each "cluster" is limited to 20kWh. Max 40 kWh in any one location, each cluster separated by 3 feet.Don't they have to be three feet apart? Or would these be tested together in "clusters" of two and three to be permitted that way?
Nah nah… I think the cut off for entry into the free server rack giveaway should be 9500 posts…Lottery for the old batteries!!!*
I don't feel so bad now..What I don't show in the videos and posts haha:
Still neater than my shop or garage…I don't feel so bad now..
Most likely the outdoor rating, and heat sink design contribute to the weight. Not to mention the heaters, and insulation…I think if you want to just buy one, or if you need ul, then probably the way to go. But I'll stick with my DIY. Under $3k each, 304ah, only 16" X 24", and around 210 pounds. I really wonder why their battery is so big and heavy. Pretty sure if I can squeeze the cells in this cabinet, they could too.
HaHa rtfm lol.I think anybody could figure it out though if they read the whole manual. I think there should be a tutorial on designating the master battery right after the communication protocol set up.
I want to see hot states test's outside.I still would need to see some real-world tests in cold environments
The metalwork is wayyyy thicker than a car, they should be fine. Who is going to do a baseball test !!!!How would this (and the 18kPV) stand up to hail?
Because of the supplied connectors and cables.I think there's a limit of three when using the eg18k per the release thread.
Coming in the Autumn I understand.What's needed is to be a UL listed ESS together with the inverter.
12" per the manual.Don't they have to be three feet apart?
RESPECT !!!!!What I don't show in the videos and posts haha:
@Will Prowse what is the Victron powering?Can't believe I moved all of those batteries after leg day ? I'm never going back. I thought, what do I really want for a system. Ruixu stack and propower packs are my favorite. Almost 60kWh:
View attachment 162426View attachment 162427View attachment 162428View attachment 162429
I need to rewire this system and make it look cool. But damn, it's beautiful! So much space!
Yeah, had to zoom in to see that small display.I think that's an MPPT RS, charging the Ruixu's.
Heh... only 6 of us in that group...Nah nah… I think the cut off for entry into the free server rack giveaway should be 9500 posts…
That would be cool with the lightsI didn't realize it until last night, but I think this battery is pretty sweet. The look, form factor, busbar with quick connectors, communication ability, internal heaters, outdoor rated and the list goes on.
Now I want to dump my server rack batteries. Which one would you rather have. This setup:
Or four of these:
I just love the look. I love sci-fi movies and I want to make a system that looks really cool. I'm thinking four batteries and an 18K would do everything I need.
The communication set up was a bit difficult. I should probably make a setup video for beginners. I think anybody could figure it out though if they read the whole manual. I think there should be a tutorial on designating the master battery right after the communication protocol set up.
But besides that, this battery is pretty impressive. I'm going to be asking all of the other companies why they don't have this type of battery. Hopefully we can get some healthy competition into the market.
What do you guys think. Is there anything that you dislike about this battery that I'm missing? I really didn't think I was going to like it but seeing it in my shop in person, makes me want only these batteries now. I think I might move my server rack batteries into my garage today. I only have two power pro batteries but I could run everything I need with them. I'm almost at 5 megawatt hours with my 18K, so I really don't need to push tons of loads through it anymore. Making a beautiful system would be fun. I want to add LED lights behind it and make it pop![]()
Have you tried it outside yet?I didn't realize it until last night, but I think this battery is pretty sweet. The look, form factor, busbar with quick connectors, communication ability, internal heaters, outdoor rated and the list goes on.
Or four of these:
