Kenny_
Solar Wizard
I installed the driver that was with the 2023 download.Do you have the correct usb drivers installed on your pc?
I don't have that specific db9 type adapter cable though.
Ah. Assumed it would have come with the batteries since it’s a PACE bmsI installed the driver that was with the 2023 download.
batteries?Ah. Assumed it would have come with the batteries since it’s a PACE bms
Yes. Pace bms in the batteries. Need to connect to them with a PC to change settings. Assumed the cables would have come in the battery packaging like Dexter noted with the SOKs in the video.batteries?
Yeah maybe they come with the SOK batteries, but not with the Sungold but I have seen places say to use that type of connecting/converting cableYes. Pace bms in the batteries. Need to connect to them with a PC to change settings. Assumed the cables would have come in the battery packaging like Dexter noted with the SOKs in the video.
Question I am getting the same unit, how did you connect the ac input sence it only hase L/N and ground separate. I was told to use red for L and black for N sence input is 240v is the correct. I have another unit but is european and the ground is bonded to the N was not sure. Any suggestions will appreciated it..Okay couple of hours later....one battery connected and inverter appears to be working... output 120 and 240 as expected. Sun is not up yet so waiting to connect panels.
Call me nervous nelly but I'm a bit afraid to disconnect from my Delta Pro and connect to the Sungold 10K.....
(the way it is currently set up it is just a matter of unplugging and plugging the power cord from the transfer switch....)
If I don't make it back let them know I gave it my best shot!![]()
Depends on how you are wiring it up. If 240 ac input then Black - L1, Red - L2, White - NQuestion I am getting the same unit, how did you connect the ac input sence it only hase L/N and ground separate. I was told to use red for L and black for N sence input is 240v is the correct
What unit are you buying?Question I am getting the same unit, how did you connect the ac input sence it only hase L/N and ground separate. I was told to use red for L and black for N sence input is 240v is the correct. I have another unit but is european and the ground is bonded to the N was not sure. Any suggestions will appreciated it..
You might be new but you're not afraid to learn. ?? ??Got my remaining 2 batteries....connected them in and the average SOC immediately dropped from 80 to 67... It's definitely reading info from the batteries....I guess...I'm new here...
But now storage up to 25.5 Kwh - my panels will have work to do to charge them all up.![]()
It's considered best practice to make sure packs are very close to the same voltage before connecting them in parallel, this reduces massive amounts of current transfer when they try to equalize.
(at least that's what I've read and makes sense to me.)
If you are only using 120 there is an alternate connection where Black feeds both L1 and L2 and White is N
take a look at the manual - you can download it before you purchase the system. It has the wiring/connection diagrams.
I think you'll love it if you don't rely on wifi or replace it as I did with Solar Assistant....and as you probably know I'm still trying to work out the battery monitoring 'issues' but it's working fine batteries, charging, AC and all!
Good Choice of inverter in my mind!
Thank for replying so the powmr I was looking at is 10k split phase well all three units are the same but I only see L/N is yours the same. So this inverter are not bonded like the 240 European.. I am sorry excuse my ignorance I seen so many post and videos on the inverters and no help..As I tell the electricians that I've had in for quotes.... I'm an Electrical Engineer (true) but that only makes me dangerous!
Yeah, I'm sure that could be an issue but they were 'close' -- the system batteries were at 70-80 SOC and the new ones were maybe 60?
You're right though....I'm hoping/trusting that the BMS will manage it if they are reasonably close...
Ahh ok that makes sence the one on Amazon or powmr is same unit but only hase L /N and ground inputWhat unit are you buying?
The one referenced in this thread has L1, L2, N and G.
Photos here. https://diysolarforum.com/threads/1mwh-srne-asf48100u200-h-10kw-??-??.67809/post-856183
My understanding is that it can be, depending on your setup. The thing I've been told is that to meet code the bonding should be done at the main AC panel only. But I'm new to this game as well.Thank for replying so the powmr I was looking at is 10k split phase well all three units are the same but I only see L/N is yours the same. So this inverter are not bonded like the 240 European.. I am sorry excuse my ignorance I seen so many post and videos on the inverters and no help..
That would be the single phase version.Ahh ok that makes sence the one on Amazon or powmr is same unit but only hase L /N and ground input
This is likely due to the sampling frequency of the inverter vs batteries. If you tap/click the inverter icon you can get raw data. (I think it refreshes faster but I haven't confirmed it).Something else besides the battery details seems off with solar assistant now.... shouldn't my load watts match my battery watts?
I thought it did before I connected the two additional batteries but now it seems wrong.
for example right now Load is showing about 200 W and battery is showing -38 watts
Ha. I used that exact tool when I hardwired my entire house. Every room has two CAT6 drops in it.I'm unsure whether to order/try the DB9 Type usb -> battery rs232 or not....I'm pretty frustrated with this whole deal.
Maybe I need one of these - https://www.amazon.com/Professional-Through-Crimping-End-Pass-Through-Connectors/dp/B07T69GMCM then I can really go to town!![]()
You'd think, but my communication with them has been problematic....seemingly mostly due to language barrier...Ha. I used that exact tool when I hardwired my entire house. Every room has two CAT6 drops in it.
Sungold has to have a solution. If anyone else is buying these batteries, there has to be a way to switch protocols via PC since they support so many supported according to documentation.
