Actually I don't have a lot of hope or confidence that the Sungold cable will solve my problem in communicating with the Sungold battery.
And beyond that even if it works with a computer/laptop I have my doubts it will work with the Raspberry Pi/Solar Assistant communicating with the battery.
I'm thinking something else may be going on with computer communicating with the Sungold Battery as was mentioned earlier like drivers or com issues on the computer.
The only thing that makes sense otherwise would be if the RJ11 connector on the Sungold Battery were wired in a non-standard way. But why would they do something like that?
In other news, I connected the Inverter to the 220 AC line I fed from above (a former air conditioner plug that I've never used in 20+ years). I know it's not optimal for full time power and inspection/certification but for now it will do (with my relatively minimal loads and not using it other than dire situations). Also it allows me to plug my clothes dryer back in full-time.
I think I'll likely continue running this way (i.e. the five batteries, the six panels, the current 5 circuits (of 6) via the transfer switch, etc.) for the remainder of the year as I evaluate the usage, Xcel Power bill, etc. It's pretty clear I'll need additional panels to keep the batteries up to top snuff. The current setup is pretty much just keeping up with my usage for those 5 circuits daily and the battery has been cycling between 40% SOC and 60% SOC.
In the mean time as I evaluate I'll probably do some minor work in wiring etc, adding breakers and cutoffs and stuff on the installation. Also I did order the battery rack from Sungold which will help a bit in getting the batteries up off the floor and add a little mobility.
P.S. the discrepency in the PV/Battery/Load numbers as reported by Solar Assistant is still annoying me significantly. My obsessiveness I guess.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm trying to get used to it but it's making me crazy. I know it wasn't like that (i.e. no discrepancy) before I added the two final batteries, but I'm also not convinced that had anything to do with it....other than perhaps something with the current surge with the unequalized batteries when I connected them. It's possible that threw something off or even broke something (current sensing in the inverter?) Dunno. Maybe if I can connect to the batteries it will be evident. I also an hoping that maybe if I get a full charge on the battery system things might 'reset' and match up again, but given the low sunlight this time of year it's not likely to happen unless I force charge from the grid.
Obligatory Pic:
![PXL_20231114_125305638.jpg PXL_20231114_125305638.jpg](https://diysolarforum.com/data/attachments/177/177676-a425b6104be00929f19f0c76fbed9658.jpg)
