Solarcabin Channel
Oh man, I deal with that every day!seemingly mostly due to language barrier
It is not always the foreign dealers and even US dealers can't seem to understand basic English or know their own products.
Yeah, That!!Oh man, I deal with that every day!
It is consistently off by about 175 watts (battery output/input off by approx. 175 Lower than Load)....This is likely due to the sampling frequency of the inverter vs batteries. If you tap/click the inverter icon you can get raw data. (I think it refreshes faster but I haven't confirmed it).
It could also be the idle consumption if you didn't program it into SA under the inverter settings in the configuration page (you have to disconnect from the inverter, in SA, before you can make the changes.)
You'd think, but my communication with them has been problematic....seemingly mostly due to language barrier...
I did go to the inverter and try changing the protocol from Pylontech to Pace and just got an error condition.
If I could go back I’d probably do conduit into a racetrack. When I add inverter 2 I am going to probably rewire. Rumor has it if you use alot of liquid tight like I did it’s a sure sign you’re a rookie ?Looking good there @Lighthouse Beacon ! I'm gonna have to get started on the mounting, conduit, etc.
Great job on all this research Kenny, I am following along and will attempt similar soon. You’re saving me a lot of work! HahaWell @ChrisG and @42OhmsPA etc... here's what Cindy from Sungold says:
Dear Mr Kenny A. Chaffin,
If you want to monitor the battery, please download the software following link to your computer.
https://drive.google.com/file/d/10TaGv_sRIYUc9-Oq1tO2tpr2oj8HpUpL/view
Please use a RS232 cable to connect the battery to the computer. The 232 to USB communication cable has a pin definition(as the picture shown). Or you can order the RS232 cable from us, and the unit price is 35USD.
Best Regards
Cindy
Which is the same software Dexter in the video said to us. Tried it with my usb -> rj11 and got the same results as with 'Dexter's' software... won't connect...so probably the cable or the pin connections .... since Cindy mentioned it...
Check windows device manager and make sure the driver is installed correctly... I've ran into so many driver issues over the years I've wanted to drive computers off a cliff.Well @ChrisG and @42OhmsPA etc... here's what Cindy from Sungold says:
Best Regards
Cindy
Hmmmm....okay....not quite sure what to look for this driver...Not seeing anything like FTDI CDM Driver.... I'm no Windows expert but that's what I've used for my entire career.Check windows device manager and make sure the driver is installed correctly... I've ran into so many driver issues over the years I've wanted to drive computers off a cliff.
I would think it would show up as a USB to serial driver. There should be an exe to install the driver with the software.Hmmmm....okay....not quite sure what to look for this driver...Not seeing anything like FTDI CDM Driver.... I'm no Windows expert but that's what I've used for my entire career.
Oh...wait I think I see it under USB ... --- oem2inf(ftdibus.inf)
and oem75inf(ftdibus.inf)
I’ve noticed my Pv production will match my load demand, so it’s almost like the inverter is asking for enough to meet load from pv so the data looks like my pv is producing less but it’s actually just being asked for lessand.... this morning....my battery charging watts + my Load Watts = the Pv Watts.... WTF??
...oops....changed....the matched there for a bit but now.....missing watts.... again ... WTF?
yes, I've seen that too when the bms slows things down towards the top of the SOC...I’ve noticed my Pv production will match my load demand, so it’s almost like the inverter is asking for enough to meet load from pv so the data looks like my pv is producing less but it’s actually just being asked for less View attachment 177378
Blue load yellow pv red ut
Use a coat or hanger or similar diameter steel rod, cut one end on an angle put the blunt other end in your drill chuck... Find out where your hole is going to come out on the other side...Got the plywood and Hardie board on the wall....knocked / drilled a hole in the living room floor above.... still gotta find it down here (i.e. cut up the drywall etc.... big mess...) and run the 220 AC input down...
and with the plywood and Hardie board over drywall I should be able to mount the inverter with the supplied mounting bolts!
Unfortunately there's a lot of wood in between...but will get it...Use a coat or hanger or similar diameter steel rod, cut one end on an angle put the blunt other end in your drill chuck... Find out where your hole is going to come out on the other side...
Any luck talking to the BMS or BMS config with Pc Kenny? I need to tweak my BMS settings I think ?Well @ChrisG and @42OhmsPA etc... here's what Cindy from Sungold says:
Best Regards
Cindy
looking at my rj11 connections I'm thinking that may be my communication issue....
Not yet and no response from Sungold yet either... I did just get one cable delivered but need the other two parts of my orders to test it...Any luck talking to the BMS or BMS config with Pc Kenny? I need to tweak my BMS settings I think ?
10/3 romex?Not yet and no response from Sungold yet either... I did just get one cable delivered but need the other two parts of my orders to test it...
I did order the cable from Current Connected use in that SOK video (same BMS apparently) no idea when it might arrive....
Glad I'm following the Bradbury method.... 'Just Jump Off the Cliff, build your Wings on the way Down'.
Now a few more pics of the day's progress
Here we go!
Got it!!
Now what do I do with it?
