Shunt your mouth!Usermode > Victron Smart Shunt > Solar Assistant > Happiness
FTFY ?Usermode > Victron Smart Shunt >bus bar > Solar Assistant > Happiness
Morathemdamnacronyms! LOL!FTFY ?
FTFY= fixed that for you hahahaMorathemdamnacronyms! LOL!
Take the bus Mable, take the bus. (don't tell Cindy!)
I knew that one but my old addled brain had to google it. Pttttt!FTFY= fixed that for you hahaha
Currently PV is hitting 4.6kw input woo-hoo!
Yep, 8 - 550w Renogy panels temp currently 35 FHow many panels do you have and what is their rating in Watt? I recall an older photo showing something like only 8 panels.
Thanks for posting this. I think it would be wise if we all posted our inverter settings into the thread and compared. I will do that when I get home... User.... User... User ?
Setting 04 - 48V or higher
05 ~53V
08 - USER
09 - 55.2V - 55.6V
10 - 90 - 120 minutes
11 - 54.8V
12 - 44V
13 - 10 seconds or so
14 - 48V
15 - 40V or higher
16 - disabled!
21 - disabled
22 - disabled
32 - SLA
Wait....I didn't quite say that rightShunt your mouth!
(up and down) button simultaneously for more than 3 seconds
Alisa seems to respond much faster than Cindy:
My email:
My concern is that menu item 12 does not return to the manually set value if the inverter loses communications with the batteries as do several other battery related settings.
If I manually set menu item 9 for example to something significantly different than what the BMS reports. I can see this value revert to the manual setting if I disconnect the BMS and revert to the BMS setting once I reconnect the BMS.
In addition, menu item 12 will turn off inverter output whereas (according to the manual) menu item 58 is just an alarm setting and does not turn off inverter output.
Since the inverter cannot determine battery state of charge but can only really monitor battery voltage it makes more sense for the inverter to respond to battery voltage issues rather than state of charge.
SGP response:
If you don't build BMS between the inverter and battery, you can try to set the inverter back to default status, here is the step:
Only connect the inverter to the battery, and press the inverter (up and down) button simultaneously for more than 3 seconds, the inverter will make a beeping sound or a white frame will appear. Then turn off the inverter and restart it.
Please kindly note that the setting of parameters should follow the following principles
【15】<【12】<【04】<【14】<【35】<【37】<【05】<【09/11】
I will have to look up each of these settings to see if the answer makes sense. Time to quite so I can go enjoy some 18 year old scotch.
Yes I had posted earlier about this "Reset to Factory" action.Undocumented functions! Not as if the manual should be considered "documentation".
I wonder if those adventures could void the warranty.
I gave my thumbs-up for posting it, but I don't like the content much.
(response time definitely depends on TOD you send the email as has been noted by I think @42OhmsPA ...Alisa seems to respond much faster than Cindy:
My email:
SGP response:
Just as Opening up and Measuring Voltages and etc as they instructed @Lighthouse Beacon to do.... Completely Useless Customer Support and Warranty Fulfillment!Undocumented functions! Not as if the manual should be considered "documentation".
I have not tried it myself but have threatened to a few times.
Not sure what those brackets and numbers and symbols even mean in @marionw 's response from Alisa.
from Alisa:
Anyone?
What?[15] means setting 15
Set 15 first, then 12, then 04, then 14 etc
Or exactly in reverse, as the < sign could mean lower priority. So setting 12 could override 15. And 04 could modify 12, which in turn modified 15.
I have not changed anything yet except set it to 485 communication.
