42OhmsPA
What's in a title?
9 is bulk, 11 is float, this is not related to the BMS... When you enable comms SOC takes over and the BMS is telling the inverter the SOC... In User 9 and 11 take affect based on voltage...Interesting.... 5 make sense that way...would be my preference as well.
on mine the BMS set value for 9 and 11 is 56.4 significantly more but others are saying theirs is set to 57.6 for 9 and 11
On voltages.... There was great advice given to meter voltage at the inverter terminals and the batteries, I see ~0.04V difference.
I'm fairly certain user will take care of this... It will charge at max current available until you hit the programmed voltage...as far as balance threshold I'm never getting anywhere near 3.4/cell ?? right now max on all 5 packs is 3.321 .... maybe I don't understand what this does but if the cells never reach that voltage then is doesn't matter anyway, right?
Thanks!
All I know for certain is my only issues have been user induced until I dialed in settings, otherwise USER settings have been rock solid.
