Fully charged by mid afternoon...maybe still a bit of balancing going on...
and btw the changes I made to the bms last night (Balance Threshold (3.5 -> 3.4 and Balance Delta 30 -> 20) did not change in all 5 BMSs as I thought. It has to do with connecting, disconnecting and reconnecting to the new battery... the PBMStools seems to hold the info in the BMS Parameters screen unless you follow the full disconnect the application, unplug and move the rs232 cable , reconnect, re-read the BMS Parameters.
(If you reread them without disconnecting and reconnecting it appears to hold the previous information)
