Bluedog225
Texas
- Nov 18, 2019
- 2,917
What will happen if I run this table saw (13 amps, 120 volts, 1560 watts) with a victron 12 volt, 1200 watt inverter and a 200 amp SOK battery?
The inverters “peak power” is listed at 2200 watts and it has a 200 amp replaceable fuse.
Specifically, will it blow a fuse? Shut down to protect itself? Let out the magic smoke?
I’m thinking little cuts (less than 5 minutes) will be ok. This is in place of starting up the genny.
1. Is that correct?
2. What happens if I run a much bigger load? That is, will the inverter protect itself or will I damage it? I don’t want to kill it as I am testing it’s limits.
Many thanks.
1. Is that correct?
Many thanks.
