Is inhaling diesel fumes a few hours a day in an enclosed space (van) bad for your health?
Gueyog8a7
UK
In this video david mckluckie, who seems highly regarded on these forums for his self powered diesel heater, argues that it is perfectly safe to exhaust the fumes directly into the space where you are in so long as the carbon monoxide alarm isn't going off. In the description I noticed he added that he thinks it is no worse than taking a walk by a busy roadside.
This seems disingenuous since it only seems to be taking acute toxicity into consideration.
Now I am certainly not exhausting everything into the van but there are still some little leaks. The monoxide alarm doesn't go off and have a 100mm fan running 24/7 out the roof (best thing I did for reducing condensation). I have tried sealing all around the gaps I could find yet still some smell emits from it during operation. I think there must be some gaps behind the fan where I am not able to get to.
I wonder how bad it is. I notice the smell is mainly when it just starts up and settles down after the stove is fully combusting. Even so combusted diesel is not good is it? Wondering just how bad as I am using every day.
I suppose the best way to get a more accurate reading of just how much is coming out and if it is going to be possibly detrimental to the health is to buy a VOC monitor but those things are not cheap starting at a couple hundred pounds. Then again one should not put a price on health. Better that than some cancer a few years down the line.
Both your combustion intake and exhaust should both be outside, otherwise you are pulling in cold air from outside into your living space and waste energy. This can potentially draw in combustion fumes too.
I’m not aware that taking a walk by a busy roadside is considered good for your health, so it’s a weird analogy. There are particulates and other not so nice gases that won’t improve your health. Find another YouTube channel!!
Have been following a MD who specializes in environmental medicine. It is humbling to learn how exhaust from other vehicles affects one during rush hour traffic.
Something is not right with your installation if you can smell exhaust. A diesel heater when tuned right doesn't produce much CO but it still produces soot particles that are bad for your health. I use a diesel heater every day, using one right now, and do not get any smell or CO in my living space.
Breathing any type of exhaust from burnt hydrocarbons has to be bad for your health. I returned one of those forced air jet kerosene heaters for that reason. Was running it in a garage with the overhead door open and couldn't believe the stink and smell. Nauseating.
Diesel stoves are not the same as normal heaters. The intake and exhaust pipes are actually inside the van because the stove has to be raised to a level to cook on.
Even the wallas instruction manual says to expect a smell which indicates it is not an installation issue if they had to put it in their manual. See this previous post from mikefitz on the subject.
Yea I get that it is worst than breathing fresh air. I am just wondering how bad. I mean humans have inhaled fumes from campfires since as long as we know and now that is said to be really bad for you too. I am not saying doing what we did in the past is good and sure life expentancy was low in previous times but there were still people that lived to old age.
There are still hunter gatherer societies today I am sure that use fires to cook daily.
I am just wondering how comparatively bad it is. Again I am not advocating exhausting the whole thing like in the video but just wondering about the minor leak I am talking about.
The stove actually also has a stink even when not cooking. I am inhaling it now. It smells like a dirty exhaust pipe even when not burning! I notice it also when in bed as the stove is only a foot or two from my head and the smells just emanate from it.
I really don't get where it is coming from because I sealed as best as I could manage at the time around the intake and exhaust pipes with a heat resistant sealant as well as any seams as mentioned earlier. It just seems to emanate a constant smell in use or even at rest.
I suppose that also leads to another question of whether the smell it emits when not burning anything is harmful or not?
I work in mine underground.
Everything is diesel powered with a few electric exception.
I breath diesel fumes all day.
The biggest concern is the particulates, those penetrate your lungs and get into your blood vessels.
It causes all kinds of issues from lung cancer to heart disease.
Metals from CAT converters also can be detected in blood and studies show they are toxic cumulative toxins
The current levels for emissions are 25PPM of CO for a 8 hour shift and the particulate rules have recently been lowered but I cant quote the spec on that.
Then you get your NOX these causes all kinds of irritation...
You can live in a Diesel exhaust but its bad for you.
Its not like gasoline engine emissions that are actually cleaner but higher in CO in modern emissions controlled engines.
CO is the killer beware of the CO if your running gasoline or diesel equipment
Could you let us know what brand and model diesel heater you've found emits little or no smell? Also, in general if you could share pros and cons about it that might help. Especially helpful if it can also be used to cook. Thanks.
I like the answer from @DPC . He details the concept of relativity. Many things in life are relative - no black or white answer so you have to make some decisions as to what's within your real choices.
It's unlikely that we'll find clear published medical research on how bad the diesel fumes are in your specific situation. Hard to get volunteers for medical studies exposing them to something that is known to be bad (just to find out HOW bad it is relative to fumes on a congested street for example).
Bryan Johnson made a comparison here:
or google it or try: http://toi.in/Y6u1Pa19
Basically, you can measure your air quality like he did. It's unlikely your air is as bad as what he experienced in India (he analogized it to being more important for India to fix its air quality (prevention) than to cure cancer (reactive cure). Your situation is likely similar. WHEN you can afford to do so: get a cleaner burning heater / heating / cooking system.
Then use your diesel heat as back up to that.
An interim step to those two would be to experiment with (when or if cool / safe to do so) COVERING the diesel heater so as to prevent fumes from emitting. Or if as hotter weather approaches see to what extent one might not use it, or only use it outside of the van. Or put it outside the van (on the roof?).
I once had a near empty diesel fuel tank in my garage. It was empty as I could reasonably have made it empty (as I didn't want to waste fuel). Even in relatively cold weather, as I approached the empty disconnected unused diesel tank, I could smell diesel fumes. It would have probably made it hard for me to sleep right next to it. NO emissions coming out...just the vapor / molecular mix with regular air. Sun or heat might make the smell stronger. And the garage was not very drafty. Often I, too, could smell it from at least a few feet away.
Alternatives to consider might include a battery bank and range from electric blankets to hot water kettles and bottles.
Here in the US, I've heard of some Van / RV folks figuring out ways to charge their battery banks from Telsa / EV chargers!
Realize too, some people are more sensitive to different carcinogens than others. Some people smoke and live over 90. Maybe you're one of those people. If the smell is bothering you, it may be God's / the Universe's way of telling you to make replacing this diesel heater your summer project. And life longevity project.
David McKluckie, Applicant for this year's Darwin Award
Think of all the people who grew up in the pre emissions control days. Cars running leaded fuel. Houses heated with coal. Asbestos in everything. Smoking was considered the norm. Water quality standards, does it look/smell/taste fine, drink it. And these people still live to be 100+ (sometimes).
Everything is bad for you. Go breath pure oxygen, and that has exposure limits before you have problems.
But burning that in an enclosed space, highly concentrated. Way more than being outside in traffic. Short term exposure, could care less. Continous, pass.
Diesels in mines, accept. There is a very high air turnover rate in mines. The modern diesels are really clean. Once warmed up and all systems up and running there is little more than water and CO2 coming out the exhaust.
I've heard of people trying to kill themselves. Go start the car up in the garage and let it idle. Modern gasoline engines are crazy clean as well. Once the cats are warmed up and the computer is keeping everything in check. After a few hours all they have is a headache from high CO2 levels.
The parking heaters he makes all the videos of, they don't have any emissions controls. Just burn diesel in air. They do a pretty good job of it, if tuned for the altitude. But they are not clean by any modern exhaust standards.
Not as clean as you might think.
Its nothing for me to blow all kinds of soot out of my nose as well as dust and filth I breath in
