MurphyGuy
It just needs a bigger hammer
- May 20, 2020
- 4,129
We make black powder for fun.. Also make PETN and HMTD and loads and loads of nitrocellulose.True but, you are not likely to smelt iron, make gunpowder, draw copper into wire, spin cotton thread (unless you live where that is grown) ...
The HMTD is used to make caps to set off other stuff..
Why would we need to draw copper into wire? Even in a total collapse of society, copper wire is everywhere. There's no need to make stuff or store things that are ubiquitous unless they are perishable or consumables.
If I understand the point you're trying to make, it is that without modern tech, a lot of the things that make our lives go will be unavailable. I think that is only a little bit true, a very little bit. Sure, there will be things that are no longer available, but most of that is stuff that we can, and probably should do without, even in normal times.
No one needs fast food, television, video games, or an automatic coffee maker.. (we can argue about the coffee maker later LOL).
An all out nuclear exchange or a devastating EMP is not going to permanently set society back to the proverbial stone age. Even in a worse case scenario, things would start getting back to a "new normal" within five or ten years. Most of the population will have died off so more resources available for the rest.What is stockpiled could help you get by until 90% to 99% of the population has died off. Eventually you'll be back to the state of early settlers in the West or of North America, minus the supply chain of such materials. Not even cloth flower sacks available, so wear buckskin (assuming the hungry hordes haven't driven deer to extinction.) Your axe and pick should last a lifetime. Most things will be made of wood and dirt. But many generations can salvage older vehicle frames to make such tools (with difficulty when hacksaw blades and acetylene run out).
Sure, it would hurt, it would also create a new way of life for people, but humans are an inventive and clever bunch and we'd get society going again in short order.
The permanent "mad max" scenario seems like a Hollywood fantasy to me.. pretty much all dystopian plots are a fantasy. The first two years would be hard, but after the dust has settled, people would quickly get back to work trading and building, and with the knowledge we have already gained, the rebuilding process would be fast and productive.
