What is the DL24 max test current spec?
You also need to upgrade use ring lug and good size wire gauge (for the current test), the Voltage sense wire can be small.
100W/ 3.3V = 30A.
You cannot exceed tester max test current handling, max Watt?
For example, if the DL24 has 20A max current, then at 3.3V the max power will be 66W.
Is this the DL24 you have?
-Product Parameter--
Electrical parameters
Test voltage:2~200V
Working current:0.2~20A
DL24 Discharge power: Voltage * current < 150 W
DL24P Discharge power: voltage * current < 180 W
(The actual running current is limited by the maximum power, please adjust the current according to the law of energy conservation)
The built-in over-current, over-temperature, over-power safety protection functions, if the protection interface is popped up, please pay attention to the parameter adjustment, shall adjust to the maximum power, and then discharge, you can first slowly and smoothly adjust the preset value in the start and discharge, in order to adjust up to the maximum power for discharging
Four operating modes of operation
1.Constant current operation(CC)
2.Constant resistance operation(CR)
3. Constant power operation(CP)
4. Constant voltage operation(CV)
