I have reviewed most of the threads on this topic, but unable to find an answer.
I have an LED shop light plugged in directly to the AC output and getting flickering every 1 to 1.5 seconds.
Setup:
1 lv6548
2 EG4-LL 48v batteries
30 amp panel in cabin directly from the LV6548
Turned off PV input, running only on batteries and no change in flicker.
Turned off batteries but not enough solar coming in to run. Lv6548 shut down AC output. Turned batteries back on and flicker still there but way less noticeable. In fact, while I am typing this flicker is only once in awhile now with no decrernable pattern. Will try again when there is enough solar to run directly without batteries.
In the meantime, does anyone have any thoughts?
There is a slight flicker occasionally in the cabin lights, but never too bad.
Thank you in advance!
Setup:
1 lv6548
