I run a pair of LV6548's purchased in December 2021. I had purchased these, never installed them, then decided to move my array and wanted a higher VOC limit so purchased a pair of EG4 6500EX's. I could not fix the flickering light problem and voltage fluctuations even with replacement 6500EX's, yet I installed the LV6548's and never had a flicker. I did install a pair of the EG4 100A MPPT's so I could still run higher VOC and I don't use the MPPT's in the LV6548's. The EG4 100A MPPT's are waiting on a firmware update to fix a F01 code that sets intermittently, other than that the pair do work well.
Whether the LV6548's had hardware and firmware changes since I purchased mine, I can't say. The LV6548V does have a higher idle amp draw. I never updated the firmware in my LV6548's either, I don't even know if an update exists as these just work. They run my entire house, I've not had a single problem with the LV6548's.
