Jazzmonger
Hacker at heart
I'm installing 2 of these in 180 degree/240v parallel configuration giving me 12kw total production, what is the maximum size of the circuit disconnect beaker I use on each output leg? 12kw= 100A at 120v and 50A at 240v. So 2 x 50A breakers, one on L1 and one on L2?
or do I put 25 A breakers on each L1 & L2 output on both inverters (total of 4). The parallel config is giving me heartburn.
I’m also confused as to why the bypass current breaker is only 40A, not 50A? Esp if these units are rated for 6kw each?
Jeff
Jeff
