That is a lot, and while days are longer, high temperatures reduce production and increase demand.
The most I've ever observed was just over 100 kWh/day, and that was a cool spring day.
If you get 6 hours effective sun, need about 25kW of inverter and 25kW (PTC or NOCT) of PV.
Two arrays tilted to about 10:00 AM and 3:00 PM summer sun, wired in parallel, could be better with flattened power curve. Then maybe 15kW or 20kW of inverter would effectively utilize the production
Consider a PV-direct A/C, hopefully designed to consume 100% of available PV. Have that on a thermostat set lower than your grid-powered central unit. That would use all available PV for cooling, only draw from grid when that is insufficient.
This PV direct mini-split might do it:
Signature Solar provides solar panels, off-grid solar systems, grid-tie, and hybrid systems. Quality solar inverters, bifacial solar panels, complete solar kits, solar batteries. Featuring brands such as EG4 Electronics with their solar battery, LifePower4 and EG4 LLifePower4 and EG4 LL
signaturesolar.com
I'd like to boost efficiency of an AC by dumping heat to water instead of hot ambient air. Maybe a mist would help cool condenser, or maybe that would be a problem for corrosion or minerals - I would think the HVAC guys here have seen it tried. My A/C has a long copper tube from outside condenser to inside evaporator. I'd like to put a water jacket around that and circulate to pool.
