Capt Bill
Sailing Options
Just saw good deal price for flexible braided copper bus bars on Docan Power's website (though says 32 min. order/ when I tried order; ... looks like it might go through w a battery order/ or explore via asking Docan for DIYSolar support for solo sample type order :
www.docanpower.com
... I only need 28 for my 2 x 24v 280Ah LifePO4 Battery Banks. It looks like the 50mm wide braided is rated for 200 amps in China on Alibabaexpress. .. I was considering doubling up the Docan bus bars on my 280 Ah Eve Cells to make sure they could handle a 1.0C ... 280 Max Amp Flow to match the 300 Amp Breaker Fuses of each battery bank (for safety ... even though I likely not see that high of amperage).
The Amp specs are missing at Docan (so far) for mm2 vs; ... but here is some info from alibabaexpress; w the 50 mm2 rated for 200 amps, and wider 75 mm2 braided bus bars rated for 400 amps.
Gold M6 Size Flexible Busbar CAN BENT LiFePO4 Battery cells 280Ah 302Ah 304Ah 320Ah Metal Connector
ModelM6 size copper Flexible Busbar(Gold M6)Load current300AApply to Lifepo4270Ah, 280Ah, 302Ah 304Ah 310Ah 320AhMaterialCopperNormal torque<0.7N.mSize190*20*2mm for 270Ah, 280Ah, 302Ah 304Ah 310Ah 320AhSize2Baided busbar 90*20*4mm for 270Ah, 280Ah, 302Ah 304Ah 310Ah 320AhSize379*20*2mm for 100Ah 10
