I had considered that as a concern but decided it was not a significant issue because:
- They are supposed to be under the load so assessing their physical dimensions not under load is not something that can really be evaluated.
- When stacking cells together, if the areas that have bulged are in different locations (one in the top half and the next one in the bottom half vs two cells where the swelling is both in the middle) the overall dimension is meaningless.
I am adding 3mm drawer liner to the sides of each and every cell to help mitigate. I appreciate the solution is not perfect but using springs is a far from perfect solution in the first place so as long as I am kind of in the ball park Im happy. The biggest reason I am using springs is so I dont severely over compress.
The pressure is not dependent on state of charge. It is a constant pressure regardless of SOC. It is not a pressure based on SOC. There are a bunch of theories floating around on where the target pressure should be set but they are all speculation and best guesses. The springs I chose have a large difference between free and solid dimension and a relatively low spring rate so as the cells expand and contract based on their state of charge there will be relatively little change in force on the cells so Im setting mine at 50% soc. They are 4 inch spring but I have room so I get that luxury.
I really like these springs you’ve found and will probably get my springs from that same supplier.
One think I like about that supplier is that they provide lifetime based on compression % and more or less force you to retain headroom (since they don’t recommend going above a % compression which is below solid).
Those springs allow you to calibrate lbs of force through rotations on a thread (as will pretty much any specified compression spring). The specs may be off and it might be nice to ‘trust but verify’ with a force sensor, but you could say that about almost anything you purchase, so going by specified spring rate is the pragmatic way to pr
I’ve been thinking more about how I will calibrate my fixture once it is ready and here are my thoughts:
I’m targeting 4mm of travel between 0% SOC and 100% SOC for my 1-row 8S battery but that is only after several cycles and initial travel will be as much as 8mm or even possibly as much as 12mm (which is what I get at 100% when not using any fixture).
I think I’ve found a spring solution that will provide ~2psi (110 lbs total) over 4mm and can reach a maximum compression of over 14psi (with headroom), so my goal is to ‘settle’ at ~13.1psi @ 100% SOC at which point 0% should end up close to 11.1psi @ 0% SOC.
And here is my plan to calibrate my fixture to settle at that level:
1/ Attach fixture to cells at unknown SOC (50% +/-40%) and calibrate springs for max target pressure (13.1psi in my case).
2/ Discharge to 0%, estimate psi by loosening to Free, then tighten to 6psi (minimum recommended compression).
3/ Charge to 100%, estimate psi by loosening to Free (should be below 100% max target pressure), then tighten to max target pressure (recording that delta).
4/ Discharge to 0%, estimate psi by measuring spring length, and repeat step 3 until delta approaches 0 (should take 2-3 cycles).
At this point, your max pressure when fully-charged will be where you want it to be (13.1psi in my case) and your min pressure when fully discharged will be determined by the actual compression (anti-expansion) of your pack (11.1psi in my case assuming actual expansion is ~4mm or 0.5mm/cell).
