Post your Ground Mount Setup
Mount 2-1, front to rear brace forms a rectangle and a triangle, subjecting rear upright to torsional loads.
I'd run that from top of front to bottom of rear, for all triangles.
Mount 3-1, no left-right diagonal braces.
I'd add a couple for earthquake resistance.
Mount 3-1, are those Delta LA-602 oil field "silicon varistor" lighting arrestors?
:ROFLMAO: :eek::mad::poop::geek:
(Be sure to watch Midnight's videos linked in post #4)
Mount 13-1, I see green wire.
Do you have a wire from PV frames back to chassis of SCC or inverter? If so, good!
Mount 1-1, are all panels oriented same?
I would have liked some strings oriented SE, some SW, for lower peak longer time of production (depending on usage.)
If net metering, best orientation depends on time of use rates.
When looking at mount 2-1 the camera perspective and angle of the ground alters the perspective of the phono and our eye. That cross brace is in fact not horizontal and no triangle is formed. It's an optical distortion.
Mount 3-1 left to right braces not required for wind loads in our locale. Mount design drawn by a solar engineer and permitted. Each concrete block weight is about 1100 pounds each. That's 6000 pounds of weight and the blocks are 24 x24 x 24 inches, about 10 inches into the ground to prevent sliding.
Yes, those are Delta lightening arrestors. I also have them mounted to Midnite Solar combiner boxes. We get maybe 4 lightening events a year hear and that would be a lot. I know about the Midnite LED, but that simply is not a concern worth the hundreds extra in this locale. But if I was back in Florida, I sure would spend the extra on Midnite arrestors.
All panels face south at 27 degree tilt. Remember, this was 2015-17 and nobody even knew much about net metering 2 let alone 3 and the changes. But yes, today, I would like a Southwest facing array too.
Mount 13-1 green wire: So at each array is a 10 foot grounding rod. Connected to the grounding rod is solid copper bare wire #8 I believe. This wire travels from the grounding rod and is bonded with UL approved ground connectors to each panel. the panels and their connections ground out to the array galvanized pipe and cross pieces. The grounding wire then connects into the Midnite Solar Combiner box which contains a grounding buss bar. The bare wire then completes the loop back to the ground rod, all uninterrupted. The green wire you see is connected to the combiner box buss bar. so is the Delta lightening arrestor ground connector. From the combiner box (which contains Midnite Solar 15 amp fuses for each parallel string, travels the PV +, PV- and the THHN green ground wire into PVC conduit. All of the arrays converge at a Schneider electric DC disconnect switch. The PV+ sides are solar fused across the blade switch, the negative PV passes through and the box is also grounded with a buss bar. This travels into the load center where the ground wire terminates on a buss bar that is also connected to two 10 foot grounding rods at that location connected by bare copper wire into that ground buss. So five grounding rods, 3 at arrays, 2 at the load center and inverter. From the buss bar, the PV wire passes thorough another DC breaker to the charge controllers which accept input as PV+, PV- and ground and output to the batteries as PV + and PV-. It's a little hard to write out, but it works.
OK, not a rectangle. Horizontal or slope, it is still a parallelogram. It resists wind pressure, and earthquakes, based on the torsional strength of the pipes.
My recommendation is to change connections to top & bottom of uprights, so it is entirely rectangles triangles.
Maybe not for wind. Do you get earthquakes? My SWAG is 1g horizontally, and shaking repeatedly.
I have diagonal braces left/right.
Have you looked at the voltage clamping curves published by Delta?
I have absolutely no reason to believe them. On a whim I tested mine, and found it held off 5000Vrms (about 7000Vpeak) without clamping.
I contacted Midnight, who's engineers are about the most respected and have been around the longest of anyone in the alternative energy industry. They just replied wryly, "Cut the end off and pour the sand out."
"Silicon Dioxide Varistor" my @$$!
Watch Midnight's videos. Absolutely nothing happened. Until cranked up to 50,000V, and then they blew apart.
I didn't want to spend the hundred fifty bucks either.
Some of my inverters have MOV installed on PV lines, but not all. I ordered more from Digikey.
For the AC side I was going to build one similar to Midnights, but ended up getting an unused industrial one for the same $150 price.
yeah, mine is aimed South West, was all one orientation. Based on time of use in 2003 (Noon to 6:00 PM.)
Now that peak is 4:00 to 9:00 PM, I've added about 33% more aimed almost due West.
I understand a bunch of ground rods, but it wasn't clear to me the network of conductors for ground go all the way back to chassis of inverter (or SCC).
''where the ground wire terminates on a buss bar that is also connected to two 10 foot grounding rods at that location" makes it sound like it stops short of the inverter.
That is the primary thing I'm concerned with. Wire from inverter to PV panel frames ensures fault current, in the event of a short to PV frame, gets back to inverter without having to go through dirt (or people.) Also, some inverters drive AC onto PV+/-, and people have gotten shocks off the frames, until they completed the circuit with a wire.
My Frankenmount for Oct and Nov. of this year. I disassembled it for the winter and will be making a proper mounting system next year with a total of 12 Felicity solar 100w panels. 24v Eco-worthy 3000w Hybrid all in one with 4 100ah batteries connected to a Honda EU7000is generator.PXL_20230920_202514486.jpgPXL_20231013_202938236.jpgPXL_20231113_223225891new.jpg
Do you have a picture of the back? Would like to see how everything is fastened together. It looks very clean from the front.
I’ll have to take one and post it. It’s just unistrut and wood with some WIP. (Wiring In Progress). I’m not 100% satisfied with the design yet and may add on more to improve integrity. My engineer buddy saw it, rolled his eyes, and mumbled something about four points of contact.
The ground mount using the concrete blocks are connected in an uneven quadrangle format. ALL of California is in an earthquake zone. The engineering design met code and there is no habitable structure near it so I guess if it collapses, no one gets hurt. The structure is schedule 40 2 inch galvanized pipe and Hollaender connections. The rails are Prosolar. The design concern for permitting was mainly concerned with wind loading, proper grounding, heights, trench depths and wire gauges. Earthquake not at all since there are always tremors here, just not the big one. As for the Delta lightening arrestors, they are mainly cosmetic here as we just don't get lightening. I am not endorsing them or advising on them.
Regarding the grounding rods. Each array has a ground rod pounded in at the array. the inverter and attached equipment plus load centers and breaker boxes are connected to ground by two grounding rods, spaced 10 feet apart, in the ground just on the other side of the garage wall. This ground wire enters through garage wall and is connected to a large ground buss bar in a load center where it then grounds the inverter, batteries, sub-panels, conduits as well as makes the connection with the ground wire out to the arrays.
So besides the garage not being a ground mount, technically the rest is. Built a pergola this summer with 8 panels atop, put 4 on the coop, 4 behind the house, and built an extension onto the garage to house 8 panels. On the garage sets 18 panels for a total of 42 which is probably my max, as I will not put any on the house.
Veeeraa Nice!!
I'm kinda thinking of something like that for my more permanent setup...when/if I ever get there...
and or doing something with my rear patio roof/cover that needs replacing anyway...
Are you powering those lights from the solar panels the lights shine on? ;)
? The battery in the light was in fact charged via the old LG Neon's. I have been tempted to throw a 100w panel under some grow lights for experimentation.
(How much electricity can we generate by campfire light?)
How many Peltier modules are we using and what kind of temperature gradients are we working with?
Co-generation. The light falls on PV panels, and the hot exhaust goes through chimney with Peltier to heat water.
I guess we could recycle old batteries by burning the lithium. Although I think magnesium may provide better spectrum.
Hopefully it doesn't snow much. Need some dirt digging equipment to make some room for snow shedding
Was is the leading clearance to ground on the high end? What is the tilt angle?
Sinclair was hesitant when I told them I wanted 4 foot between ground level and leading edge at full tilt. Plus I will be setting posts in concrete.
I'm at 48 degree tilt on both arrays. Eyeball measuring says 18 inches from bottom of panel to the ground. Not sure on the downhill side the clearance.
Single post of course resists less force the taller it is.
Braced as triangles (teepee), should support much taller.
Just for reference, my Sinclair is at 62 degrees for winter, one end of my array is 24" above grade, and the other end is 32" above grade. This is perfectly stable. I do have a heavy wooded area right behind this array to help with wind if that matters.
I believe it does. This dog-eared fencing not only covers the underside of my array from view but more importantly, helps keep the wind from lifting it. Plus I have a lot of trees around my property which knock down the wind gusts we frequently get here.
