This is what I have. I don’t have experience with it in the hot weather yet. I’ll post details when I do. But like others said, it’s highly dependent on insulation, size of rig, awnings, and other variables.Since there was so much chatter recently got me looking and came across this nicely done factory equipped mini split in rv.
Nice thing about this is the ceiling venting!
I presume that it would be more like 7500W / 19 = 468W per hour... A bit more, but perhaps still not enough.1800 watts x 80% (realistic factor) is ~1500w x 5 hours gives you 7500w to play with / 24 hours = 312.5 watts per hour. Me say no.... Unless you supplement with a generator or grid.
I would add that it must recharge batteries AND provide power used in #1).2) And while the sun is shining, can the solar panels fully recharge the battery bank?
(The size of the solar array could be derived from the answer to that question)
I think I can get more than 5 hours most of the year. Even when the sun is low in the sky my 2k array is putting out 500w most of the time. Probably from 9-6 right now. I just ordered a 9k BTU AC for my work shop, so we'll see. I don't expect my little 6kwh battery pack to make it through the night running the AC, but I am hoping it will keep the room cool while I am there. After I build my house, I will have grid to fill in during the night, so no issues.I presume that it would be more like 7500W / 19 = 468W per hour... A bit more, but perhaps still not enough.
I say 19 with the assumption that during the 5 hours of ~full~ Solar the batteries are just charging, 24 - 5 = 19.
Does that seem reasonable?
Yes, that's the implication... I will amend to make that clear.I would add that it must recharge batteries AND provide power used in #1).
Wow... That's a boat-load of power... Consumed & produced!Check out my graphs for Sunday through Today: https://vrm.victronenergy.com/installation/76892/share/d5bbdd04 ... 90F temps, full sun (today is supposed to get cloudy and stormy in the afternoon). My usual load is about 5kWh/day without the AC so the AC is adding another 10 or so.. and I'm able to produce enough to both run it and recover the batteries by 1pm (3.3kW solar, 27kWh battery).
Yes you can. I just put up a new thread on this. With your solar count, you should have no problems. I'm doing it 2 years now with under 1000w coming in.Ok, I have watched videos till my eyes are crossing and my mind is numb!
I guess i'm just that dense!!
I am installing a 12000 BTU mini split in my Cargo Conversion Toy Hauler. I have a small 110v fridge (Dormer style) and the Mini says it pulls 9.1 AMP (At startup) and reduces down after room temp gets where it satisfies the thermostat. It then cycles on and off.
My question is, if I install 1800 watts of solar on the roof and have 400ah of Lithium Ion, Will I be able to run it 24/7?
I know there are calculators and other sources out there, but I just need some advice on whether I'm headed in the right direction or just full of crap!! Could be the latter. LOL
Even had me in tears....Man I really sounded negative in that last message
link?Yes you can. I just put up a new thread on this. With your solar count, you should have no problems. I'm doing it 2 years now with under 1000w coming in.
link?
I just (literally) had a 9k btu unit delivered by FedEx just now. I probably won't get around to installing it this weekend, but I am pretty excited to be finally trying it. I know my battery/solar will not run it full time, but it might be just enough to keep me comfortable while I am in the workshop.
didnt work for me i am using 1k every hour with my 1200watt panel and 300useable AH on my SLA everstart 29dc MAXX maybe with a 400AH at 48volt LFP plus 5kw panels will be greatLOL!! Sound advice!! I plan to install up to 2000 watts. (that's all I can fit) and the 400ah lithium battery. Carry the generator just in case and we will see! Maybe I will need a second 400ah battery. Who knows.
proper cap? are you refering to SUPER CAPS? do you have a good link for a 48 volt system????A proper cap should help either way.
