Here are some alternatives.
Magic Tank in a Non-Flammable emergency fuel that's legal and safe to store in your vehicle. If you run out of gas or you are running out of gas, pour Magic Tank into your gas tank and Magic Tank will
www.homedepot.com
VP 4 CYCLE FUEL delivers quicker, more reliable starts. Our ethanol-free fuel keeps your outdoor power equipment running at peak performance & extends engine life. It passes the warranty requirements of all 4-cycle engine manufacturers. Eliminates the need for and cost of adding fuel stabilizers...
www.acehardware.com
If you keep gasoline in a sealed container ( I use a small drum ) and you add fuel stabilizer to it and you rotate your fuel you don;t need any of that.
Every time I need to mow the lawn I do it with fuel from this drum.
I symphony off 2 1/2 gallons, I top off with the same fresh from where ever I am buying gas these days.
Sometimes I pull sometimes I pour some ion my car so I can refresh the drum with a few gallons every month.
Gas will be good forever as long as I do that.
To the left is a gold coloured generator.
That's Honda with a fuel pump bolted to a Kohler generator.
I connect the fuel line and thats about as much fuel as I will need to run that little set for days maybe a week if I ration carefully
Lets say I hear there will be a tornado warning blizzard ice storm and I get scared...
I can go out by another 10 gallons of gas to sit on in some septre gas cans.
I've never needed it but I have it and then I just draw 5 gallons off from the drum to refuel my car and another 5 gallons next time I need to refill it again...
Now that drum is very well refreshed and I don't need to worry about old fuel.
That little drum will also fit in my trunk.
If I had too I could go to a gas station and fill the drum and bring it home ( about 16 gallons )
Yes you can buy military style Gerry cans but they are not drums....
A can is easy to steal but someone will think twice about trying to run down the street with a drum.
